Power Steering Cooler
With my A&A Supercharger installed the power steering cooler is squeezed hard between the 3" cooler hose and cross member. Is there any negative affects as a result of removing the cooler? What is the best option for removing it?
ISIS SUCKS FAT CHOAD
No there shouldn't be any issue with doing it especially on a street car. Removing it requires some power steering compliant hose and some clamps.
but if you want to keep it you could slide it right on the cradle as you are looking from the front of the car drill new holes and tap or add riv nuts after drilling new holes and remount it. Just an option.
I bought my C5 with an older A&A kit that had driver's side charge piping and power steering cooler delete since there is absolutely no room for a stock cooler.
I did not like that and decided to install and aftermarket Setrab PS cooler right in front of driver's side bumper opening. I used -6AN lines all the way to the reservoir and to power steering return.
Parts List:
Fittings
Jegs 361-809106 Qty 3
Jegs 361-991955 Qty 1
Jegs 555-100581 Qty 1
Jegs 361-800106 Qty 1
Cooler: Setrab 50-107-7612
Bracket: Setrab SET-23-1002
Then just add any standard -6AN hose. Note that these fittings are not high-pressure and cannot be used for high-pressure side of the system.
Parts List:
Fittings
The following 3 users liked this post by r0nd3L:
Received 1,261 Likes
I removed mine and just used some power steering hose to loop the connections previously used by the cooler... no biggie and I haven't had any issues... I do not track my car though, if you do I would consider moving it or adding an aftermarket cooler as suggested above
I'm in the process of moving my cooler and it looks like the line is leaking where the rubber meets the hard line. Can I just cut the stock crimp clamps, replace the rubber hose and use band clamps?
You can keep the stock cooler.All you gotta do is move it around 4-5 inch to the driver side and play with the line a little.Then you drill and tap 2 new hole for the cooler bracket and your done
don't suppose you recall what wrench size you used on the old P/S fitting? They're torqued to about a billion lb/ft on my car. I want to use flare wrenches to make sure I don't round the thing off, but suspect they're metric (and I only have SAE flare wrenches).
Thought I'd check if you recalled real quick before going out and buying metric flare wrenches. The nuts are in bad enough shape on my car it wasn't clear when checking last night...
Cheers!
-Jake
Cheers!
-Jake
Cheers!
-Jake
Cheers!
-Jake
I ad to do this kinda of job 4 times in the last 3 years and i didnt use flared wrenches the first 2 times...so i damaged them pretty badly.This year i ad to cut the hose with a metal saw and take off the fittings with locking pliers.At least a new pressure hose is kinda cheap
