Alky control help: I broke the pot,led and test switch wiring..
I emailed Julio but wanted to ask here if someone knows where the wires go
So I have a custom control panel that has holes for the "pot" the led and the test button. I have been using it this way for awhile now. Well I accidentally pulled all but one of the wires off everything and need to know where they go. I understand the pot has 3 terminals and terminal one is ground, terminal 2 is the input and terminal 3 is the output? or do I have the last 2 backwards? Here are some pics the only thing that is still connected is the orange wire on the pot which is on it's own terminal and not part of the 3 terminals that are together.Also the white wire has a bare copper wire coming out of each other but not in the same protective sleeve if that makes sense. I also need to know which wires go to the test and led button. Thanks
You can see the white/copper wire they are separate just in one casing
Grey
black
Red
orange which is still intact
Grey
black
Red
Shan't, I'm at a local tuner shop this morning but if you haven't heard from Julio by this afternoon, I'll pull my control box cover off and send you the info. It isn't installed yet so, nbd.
I thought I was a little on the ocd side, at least that's what my wife tell me
Ed, I have to say your always there when someone needs help, and after seeing the projects that you have tackled your input goes a long way.
Very nice
Very nice
