408ci LS2 + YSI + Nitrous C5 Z06 Build
Mentioned on thread in LS1tech. 10lbs seems very low for that combo.
Update after talking to bret we found a cut hose going to the BOV
Last night numbers even though I still think we can get 850rwhp on 20-22 timing Like Bret also mentioned but the tuner said it's very safe until the smaller pulley and race fuel.
Making 18psi just before the 6900-7000rpm mid range showing 15-16psi
Any comments/Help are welcome for me I think it should make mid to high 800 on that boost level on pump and meth with more timing then 2.85 pulley on C16&Meth it should be over 950rwhp
What do you guys think? Should we go with the smaller pulley already?
Thanks for all the help and info I really appreciate it.
Solid numbers... Personally.. I like more boost and less timing. I think I'd throw the 2.75 pulley on it, pull the timing back to 15* initially, then make some pulls and see where it ends up. Then go up from there on the timing if you have a dual nozzle meth on it. I think 20-21 psi/15* will make 850 rwhp and be plenty safe on 93/meth (M15/M10).
Ofcourse all of this is strictly my opinion based on my limited experience with my own car, take it with a grain of salt... but listen to the pros...
I'll just say that more then 17* of timing scares me on 93/meth, even with accurate plug readings and seem good.
There are lots of guys here with YSIs with 2.85" pulleys making well over 950rwhp on pump/meth on similar sized engines with similar combos, so maybe you just need to spin it harder, make more power every where.
Although 800 rwhp is a great level to be at on the street....probably the best.
