My top mount single turbo build
#101
No foam, no issues.
I welded in a 4 ft piece of 1/8 inch angle iron across the inside of the crashbar just for piece of mind. More or less to protect the radiator in the event of a minor front end crash. You can kind of see it behind the intercooler. That is what that intercooler mounting tabs are welded too.
You can PM me if you want so we do clutter up the OPs thread.
Lots of bad *** turbo cars being built now days...
#102
Agreed, that is huge, bet it keeps charges cool.
#103
Ok today was a good day.
Got the fuel pump in
Got the meth pump mounted. Going to use my washer fluid tank for meth.
So as stated earlier my passenger side Spal fan was hitting my wastegate horribly... as in it wouldn't even get past it. So I ordered this mishimoto 12" slim to replace it. I had to drill the rivets out, remove the spal fan, then installed the mishimoto directly to the radiator. I then cut a 1/4" fuel hose and installed it along the edge to create a seal so that the shroud doesn't lose its effectiveness.
I know its not as good as the spal but it should work ok and now everything is happy.
More to come tomorrow! Tune is set for the 18th!
#105
Thanks guys, well wasn't able to get tuned yesterday. My damn torque tube is seized up... wtf?!?!?! Got another one so the tune will be in a couple of weeks.
#111
Ok tune date is now set for the 15th! Got the new torque tube in and all.is well. Also, got some new shoes. 17x4.5 and 16x10.5 drag pack....
More pics to come
More pics to come
#116
First drive on the base tune. Couldn't get a full tune bc I have a bad o2 sensor on the drivers side. Also, my new tires(bias ply) were not working on the dyno and hitting my fenders so I ordered some MT drag radials to remedy that.
Vid below: just a little drive in car and out of car. She sounds amazing!
#118
Ok so got it tuned yesterday... honestly disappointed tho. The car DID NOT like 91 pump gas... even with a little meth. It made decent power but wouldn't take anymore boost or timing due to detonation. Tuner said my CR is too high for pump gas.
Made 627whp and 587 tq... going back in a few weeks for an e85 tune.
#120
