finally install my wideband lean... reduce engine power..
ISIS SUCKS FAT CHOAD
If the case is really where the tuner says all he does is tune then sure. Though most of the tuners I know are capable of diagnosing and fixing issues and if they aren't themselves they know or have Someone who is. Unless I'm reading and or understanding this wrong it seems that the car left the Dyno tuner running like it was supposed to and then it began acting up.
This is why I said I don't think automatically assuming there's a tuning issue is the best course of action. I'm not saying it isn't a tuning issue but I think it's more wise to rule out everything first instead of first blaming issues on the competency of the tuner.
I guess we do agree that the car does need to be mechanically and electrically looked over to rule out mechanical or electrical issues with reasonable confidence.
This is why after reading the OP's concerns I told him it's a wise idea to check the plug wires. It's something easy that most are capable of doing. If the tuner has to do that kind of stuff I don't think he would be wrong for saying hey I'm going to charge you for it. On that same note, if he decided not to charge him for that and it fixes the stumbling breaking up, misfiring issue than that's cool too. If the OP did the check himself and discovered a problem then it's valuable info he could relay to the tuner if he decides to go back.
thanx for all the responses. a lil back round on myself im 31 years im a full time tech. i have alot of knowledge on vehicles. but dont know everything at all. this isnt my first boost car i have a procharged 2002 must GT also. only reason i got this C5 FRC was because i think i got it for a steel $15,000 with 28,xxx. he was asking $25,000 it sat for 2 years.(previous owner passed away)
ok as for last night went out to meet a friend thats got a GTO LS2 with 100 shot nitrous. he said got got 450hp and 550 TQ (i think). we went at it and i beat him all three times (roll start whateva he wanted). after getting off the highway boom my DIC say reduce engine power. fuel pressure was about 55 psi and my wide band was full lean and read (---) cycle the key still running like **** left it off for a min and it started up and smoking from the tail pipes ran normal. also when im at WOT its full rich like 10.5. fuel jumps around i think i seen it got to 45 psi quick i have a digital gauge AEM. then when i have going home it did it again. pulled over and wait then cleared up. when i got off the freeway and i did a WOt first and when i shifted to second i felt a huge hesitation like i hit the brake then took off to WOT. i real think its the MAF he delete off the system. not giving me the code.
i was referred from a buddy of mine to this tuner.
Received 1,193 Likes
St. Jude Donor '15
Need to see a log and tune.
Is it running speed density or MAF or both?
There are some tables that compare MAF vs. VE airflow for different conditions. If the difference is too high it'll throw an error or two. Not sure if it's for this one, but that's the first thing that comes to mind
im still running the MAF. he said he changed tables and it seems to be running better. but still have a hesitation around town driving normal. spikes to 16.9 on my wideband. at about 2,000 rpms. should i get the table from my tuner?
St. Jude Donor '15
Agree with the other poster.. This sounds like basic stuff. The tuner should be able to fix this stuff in his sleep
asked him for the log and tune and he said can send it cause i have no way of loading it. made a appointment monday to see him
St. Jude Donor '15
Plenty of us here can open them if he's using HP Tuners
St. Jude Donor '15
http://files.hptuners.com/VCM%20Suite/VCM%20Suite.msi for a trial of the software
You have to buy an interface if you want to do anything beyond that though. $499 or $649 depending on which version you get
