What route would you prefer for fuel system?
Old 06-24-2015, 10:48 PM
ascastil
ascastil's Avatar
Default What route would you prefer for fuel system?
Thinking of future mods, what would be the best for me taking into consideration we only have 91 octane fuel. Ill be wanting to put in a small cam to go with my supercharger. I already have a Walbro 450 running on 91 octane.
91 octane+meth or E85?
Ill need new injectors for the E85 plus a new tune, anything else? Im guessing $1000 for injectors plus $500 for a new tune, speed density I think. Roughly $1500.
For the meth setup, Alkycontrol kit is about $600 plus a new tune, $500. Roughly $1100.
What should I do?
Old 06-24-2015, 11:20 PM
4DRUSH
4DRUSH's Avatar
Most likely need bigger fuel system for E85 also
Old 06-24-2015, 11:43 PM
ascastil
ascastil's Avatar
Cant really find much with google on what else is needed. I saw a few people asking about E85 fuel systems for 1200hp, I dont need that.
I thought if I already had the pump then hopefully I could just throw in some injectors and a tune. Also was thinking E85 would be a little bit better in terms of one less thing to go wrong if I wasnt running a methanol pump.
Old 06-25-2015, 09:00 AM
cmiller8006
cmiller8006's Avatar
I like e85 vs meth injection for that reason of pump failure and inconsistent spray I have seen. However you can argue the other side and say a second fuel pump can also fail and cause a lean condition. If e85 is readily available then go with that.
Old 06-25-2015, 09:56 AM
Turbo-Geist
Turbo-Geist's Avatar
2017 C5 of Year Finalist
Originally Posted by ascastil
What should I do?
You mentioned that you only have 91 octane in your area. Is E85 readily available?
More importantly how much power are you planning to make? It's hard for anyone to speculate on your current pump selection and future fuel system capacity without a target rwhp rating.
Just as a point of reference, I made 800+ rwhp with a 255 in-tank, return style system, 93 octane and dual meth nozzles. No issues with the meth system in 4 years of use. I will be replacing the meth pump on this next build to be safe.
Old 06-25-2015, 02:07 PM
Cordes Performance Racing
Supporting Vendor
Cordes Performance Racing's Avatar
Received 1,227 Likes on 774 Posts
Aaron how much do you want to make? Just email me man I'll tell you what you need to do.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old 06-25-2015, 09:29 PM
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Support Corvetteforum!
MVP'S ZO6's Avatar
If you decide to run E85, be sure whatever injector you use is internally ready to handle the E85 because E85 likes To absorb water. A typical fuel injector don't like that! A quick search on the interwebz will yield all sorts of stuff on this topic.
Old 06-26-2015, 08:10 AM
4DRUSH
4DRUSH's Avatar
The famous last words
Old 06-26-2015, 09:31 AM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
Jay you are funny. But then again in more than not correct.
Old 06-26-2015, 10:54 AM
ascastil
ascastil's Avatar
Im thinking around 550whp. Might have to pulley down also. Im still on the stock block so Im not looking to make gobs of power. I know a lot of people would run meth. Im not even sure if one Walbro 450 would get me there. It just sounds easier and more simple to just put in injectors for E85 if it would. Theres a gas station with E85 about a mile from my house.
Old 06-26-2015, 09:10 PM
Z06supercharged
Z06supercharged's Avatar
If you have the fuel system to support it (dual pumps for sure either 1 in tank and 1 external only under boost or 2 in tank) and dont mind lower gas mileage E85 is a no brainer on a boosted application, and a station so close a big plus. Use min 1300cc injectors but id go 2000cc just in case in the future you wanna go more power.
Old 06-26-2015, 10:25 PM
cmiller8006
He said he wants 550 whp, don't need 1300's, even on E85. However I am all for room for improvement, but still wont need 2000's, I am going to run bosch 127's and with my set up should have enough for 900 whp on E85.
Old 06-26-2015, 10:29 PM
Z06supercharged
Yea my bad I'm using 2000's on another platform. I think 1300's will be fine and a single Walbro 450 for his 550whp. I wouldn't go 1000's though even for 550whp.
Old 06-27-2015, 04:54 PM
ascastil
ascastil's Avatar
So one Walbro 450 is good enough for 550ish whp with E85? I guess the better question is how much power can one 450 make with E85?
Old 06-27-2015, 07:44 PM
Milan
Milan's Avatar
Walbro 450 + Bosch 127s will be perfect for you. Add a BAP if for some reason the 450 is not enough but I have a hard time imagining it's not at 550 or less.
E85 is the ****...if you have it around you it's a no brainer compared to 91+meth.
Hell at 550 whp you could run 1000cc injectors but for the minimal price increase just do the 127s and call it day. Don't be afraid of the stock block, 550 whp is nothing ESPECIALLY with E85
To What route would you prefer for fuel system?
Quick Reply: What route would you prefer for fuel system?
