Oil Fill Breather
Oil Fill Breather
Is there an alternative to the breather that goes into to oil fill hole? Seems I saw a cap with a tube that runs into a catch can. If there is an alternative let me know where I can purchase. Thanks
Product ID: MBR0003-10AN
Valve Cover Adapter
Metco is 6 minutes from my house haha. I had never heard about them. I was looking at that adapter the other day on ebay, saw the part number you posted and figured id look it up. Was shocked when I saw the address lol. I guess I will be making a stop by tomorrow .
Received 1,194 Likes
St. Jude Donor '15
St. Jude Donor '15
Pretty much. High cylinder pressure = more blowby
Need to get that blowby out or you'll pressurize the crankcase and can blow a main seal.
Some people just run an open breather on the oil fill cap.. and that can work. The problem I had with it was the smell. The fumes coming out of the open breather cap would get into the cabin through the vents near the windshield wipers and I hated it. Made my head spin.
The mightymouse setup fixed that 100% for me and I think it looks pretty slick.
The oil cap breather was OK for me up to 11-14psi. Never had smell until I removed the PCV so I put it back. Once I got boost 14-17+psi then oil splatter becomes a problem where you want to contain it.
Thanks guys.
I see the mightymouse setup above, but is there a place I can get more info on it? I'll do some searching and see what I can come up with. Seems like I should have that at 12lbs of boost.
EDIT: Additional info for others curious about this setup
http://www.mightymousesolutions.com/#!mm-black/ca5m
https://www.corvetteforum.com/forums...an-review.html
St. Jude Donor '15
Oil Fill Breather
The owner is good to deal with too. Emailed me back even on holidays.
St. Jude Donor '15
The PCV version has a PCV valve that closes under boost.
St. Jude Donor '15
Good deal. The PCV version will have a 3/8" barb I believe for the clean side. Dirty side you can get -10AN. I got the same thing on mine.
St. Jude Donor '15
What vacuum block are you using?
St. Jude Donor '15
Oil Fill Breather
Thanks, will look into it. Was thinking of neatening up the two Hobbs switches and NPP exhaust vacuum connection.
Received 1,261 Likes
I have one similar to that made by obx that has 6 ports on top, a plug on one end, and a hose barb on the other end to connect to a vacuum source... I put it behind my driver side fender so everything is out of the engine bay to cut down on the clutter
