Weld Alumastar 2.0 15" backspace
Hey fellas. Im ready to order the front skinnies but havent heard back from Weld yet so if any of you are running a Weld 15x3.5" wheel what is the right backspacing for a 2002 C5 coupe. Im going to run drag brakes but curious if the stock brakes will fit for sitting in the shop. I dont want to grind my factory calipers so if I need to I will just remove the calipers until I get a manual drag brake setup
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Ok.
I have 15x4 with 2.5" BS.
Hope that helps some.
Oh yeh. I have the RT-S wheels. Not the really cool 2.0 wheels.
Personally I like the 4" wide front rim, seems to fit a skinny tire better
I believe 2.25" is the biggest bs offered in 4" & 1.75" for 3.5" (which is what you want)
No problem with Strange drag brake clearance.
Received 1,762 Likes
What he said here. Plus to me the 4 inch has a better feel going down the track.
