Boosted c5
Boosted c5
Hit a financial issue and am forced to sell my baby. Car is 99% done (needs to be tuned)
2001 c5 (silver) 106xxx on the body with clean PA title in hand
Quick run down
04 lq9 bottom end (stock)
241 ls1 heads (stock port)
texas speed .650 daul springs and ti retainers, new oem valves and valve seals
Texas speed stock lenth harden push rods
Solid motor mounts
Arp head studs
GM ls9 head gaskets
GM ls7 lifters
Ported ls6 oil pump
New GM water pump
Crank has been pinned
MSD plug wires
Aluminum coolant over flow
Aluminum catch can
Tick performance custom boost cam
Eldelbrock 2 peice timing cover
Holley high ram intake
Holly high flow fuel rails
Inline fuel filter with pressue gauge
80lb injectors
Intank linginfelter 255 fuel pump
Gm ls3 3 bar map
Fidanza flywheel
Spec stage 3 clutch
BnM prostock short shifter
Custom single turbo setup
Borg Warner s366r .91 ar t4 divided
3" vband down pipe (fender exit)
Battery relocated to the trunk (optima redtop)
Tial 44mm wastegate
Tial 50mm bov
Custom made and mounted intercooler
Griffin 3 row radiator and 2 slim fans
Stop tech drilled and slotted rotors
Stop tech pads
Russells steel braided brake lines
HRE 540 ( custom sandwhich mounted) 17x12 and 17x10
Rear 275 50 17 MnH et radials
Front 255 45 17 bfg pro comp all season
APR gtc500 carbon fiber wing
Stance ss full coilovers (height and dampening adjustable)
HID low beam conversion
Corbeau forza sport seats with corbeau rails and sliders
MOMO hub with nrg quick release and REAL nardi deep corn leather steering wheels
Car starts and runs.. but will need to be trailered (no tune) car has been converted to speed density (no MAF). Also will need to buy/make a hood. Car is solid and will make 6-650 whp on 93 pump gas as it sits. Fan into a bad situation and this is the only thing i actually own worth money lol sp its gotta go
Price is 20k.. firm i have over 30k into it
You want it cheaper i can take parts off and sell them separately (but only bolt ons ect. Wheels, wing, coil overs, seats.. and things like that). Will also take 1000-1500 off if you have a ls1 t56 6speed. If you dont like the price GO KICK ROCKS .. need cash to pay somthing off message me if a serious buyer
Quick run down
Solid motor mounts
Arp head studs
GM ls9 head gaskets
GM ls7 lifters
Ported ls6 oil pump
New GM water pump
MSD plug wires
Aluminum catch can
80lb injectors
Gm ls3 3 bar map
Fidanza flywheel
Spec stage 3 clutch
Tial 44mm wastegate
Tial 50mm bov
Stop tech pads
Received 2,705 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Try the forum topic:
C5 Corvettes for Sale
Classifieds: Used C5 Corvettes for sale as well as modified or stock Corvettes
