**C5 High Horse Power Club**
#82
Please add me to the list:
802/720,346CI,Forged LS1,A&A Vortech V2 Si-14LBS. of Boost,Advanced Inductions Heads,Custom Grind Comp Cam,Meth,Stock Bottom End
#84
St. Jude Donor '15-'16-'17-'18
So is the bottom end stock or not? That's a lot of power for a Si, especially when they aren't rated that high.
#85
Yes,the bottom end is stock and here is the dyno sheet-it looks like there is a couple of guys with that blower that are making more horsepower than me on the list,I did add it is a V2 blower to my description above.... Rich
#86
Ok. Your post said forged ls1 then it said stock bottom end. My concern was that you typed 800hp, not the 703 the sheet says. Got it added. Thanks!
#89
Ls1 (stock bottom as far as I know)
V3 T-trim, 3.6" pulley @ 10psi
Meth
Ported 241 heads
Unknown cam
Kooks Long tubes
653/628 with correction factor (pulled timing due to stock bottom, said he could hit 700 if he wasn't afraid of it coming apart)
Meth
Ported 241 heads
Unknown cam
Kooks Long tubes
#90
Can update mine I guess. Would have been more if clutch would have held it. Oh well.
Custom twin turbo 403ci, pump 93/meth
852hp at 14.5psi and 19deg
987hp at 18.5psi and 18deg (checked plug and had A LOT of room left)
1,051hp/970tq at 21.5psi and 15deg
Clutch wouldn't hold anymore
https://www.corvetteforum.com/forums...custom-tt.html
#92
NCM Lifetime Member
Received 3,930 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23-'24
664/614 402ci Forged, A&A V3 Si 3.6
#94
04 Base C5
Stock bottom end
Trick Flow Heads
Tourqer V2 Cam
36lb (white) FAST Injectors
Vararam Intake
C6Z Fuel Pump Module
Nitrous Outlet Wet Kit: 150shot
RPM Motorsports Tune
591whp 603ft/lbs
Stock bottom end
Trick Flow Heads
Tourqer V2 Cam
Vararam Intake
591whp 603ft/lbs
