tipot single turbo C5 build LS7 S480 :)
#161
I had an issue with the coil pack main connector (10 pin) at the valve cover that was causing a misfire problem. The issue was the female side of the connector had lost it's tension on the male side for the power and gound in the connector. I pulled my hair trying to find my misfire and that was all it was. Hope it helps you.
#162
so i got it rebuilt i guess the bearings where shot in it . maybe it affected the voltage enough to create a slight misfire . the car seems to run very strong on the street . i drove it for a couple hours last saturday to see if
i had any other issues . ill know more next week end
#163
hey guys here a small update and review of the overall new turbo build .
ive been driving the car for the last week or so . i did find a couple issues but so far all fixed . one of my big worries was the car overheating and so far its been really good . 190-200 in traffic and 185 on the highway .
power seems to come on around 3500rpm . hits pretty hard
im running around 13psi with 10.3 afr and 10 degrees timing . (800whp 850trq) it hooks pretty good in 3rd gear from a 60mph rolll
im sad the mickey thompson doesn't make the 315 45 16 any more cause they are a wicked upgrade vs the 305 35 18 i ran last year.
in the next few weeks i need to get the car street tuned again and up the boost to 15psi i will keep you guys posted how it goes
sitting pretty and dirty
#165
Hell yeah! It's refreshing to see these all out turbo builds like yours and mine (sort of). It gets boring seeing people come on here and keeping asking the same endless questions about superchargers. Good on us for being different!
#167
Glad you're enjoying it now some. Should be a fun car no doubt and on a side note, if you really are at 10.3 afr you will pick up a ton of power at the same boost by leaning it out some and still be plenty safe. My last TT car gained 70whp from 10.7-11.2 on 10psi.
#168
And taking timing out of it.
Hoping to get the car street tuned next week. Im going to leave the timing at 10 degrees and get him to lean it out to 11.0 . Will see how it runs.
So far at 15psi it feels really good on the street
#169
Oh we know this. Only thing on the dyno as soon as we leaned it out to 11.3-11.4 it would missfire . We took 100whp out of the car by tuning it rich
Really crazy that it misfires in a more ideal combustion (11.0) than in a super rich one (10.3) lol. Stranger things do happen I suppose, good luck with it!
FourG63 97GST (12-09-2016)
#171
Hey guys here is the latest update with the car. I told myself i wasnt changing anything on the exterior of the car until it was sorted out lol . Ive never been a fan of the silver stripes so yesturday we fixed that
<br >
venomws7 (05-23-2016)
#173
so the 18 inch CCW'S are sold
ill be pulling the trigger on some new Welds tomorrow
pretty pumped about doing 15's in the back .
thinking really hard on the weld S77B with beadlock
#174
Hey guys here is the latest update on the build. Old blue got some new dancing shoes . Only have a few pics for now. Had some issues with my axles being popped out .i got one side all bolted up last night . Decided to go with a fat tire up front to gain some ground clearence . ill have some pics of the car sitting in the next couple days
setup is Weld S77
18x10 275 40 18
15x10 275 60 15
setup is Weld S77
18x10 275 40 18
15x10 275 60 15
#176
front offsett is +56 and i didn't check the rear but i can tonight . i bought the rear setup from carlyle racing with the spindel . the front i ordered on my own from one of my suppliers
not sure on rubbing yet since i havent had a chance to finish assembling the passenger side axle and spindel . i had a simular setup with the CCW drag pack they didn't rub
#178
[/QUOTE]
16x10 with 315 45 16 mickey thompson
i loved the 16s but the tires are getting harder to find in proper sizes for the c5's
btw anyone looking for a nice ccw drag pack they will be for sale soon
#180
sad to say no lol . we ended up turning the power down . pig rich AFR 10.3
and 10 degrees timing it doesn't sputter at 15psi and make a little over 850whp and close to 900trq . im going to leave it like this for the summer . this winter ill most likely be swapping the cam and wtv the valve train needs . the car is lots of fun on the street with this power .cant wait to try out the 15s with this power setting
hoping to hit the track next month to try and hit a 9sec pass .always been a goal of mine banging gears
