lower radiator support or no?
with the A&A kit, do you guys still lower the radiator support (with dewitts short radiator) or you you keep factory location? Just want to make sure i won't have fitment issues.
Received 1,762 Likes
It will work fine as long as you not using a 4 inch pipe on top. You can always just cut the stock one & reweld it if using a 4 inch pipe on top & not have to hammer on the top of you other parts.
St. Jude Donor '15-'16-'17-'18
A&A has spacers with their kits. Short ones up front long in the back. If you plan on keeping the "dongle" you'll be fine with a shorty radiator, but if you do a 4" pipe you will need to space it down.
