What goes here?
What goes here?
Got my car back after 11 month ordeal from two diff shops. I noticed this line is no capped off or connected. It comes off the throttle body. DO I JUST CAP IT OFF? Both the lines to the catch can are connected. Thanks.
Would this not being capped off throw either a p0103 or p407 code? It speed density tuned.
St. Jude Donor '15-'16-'17-'18
It should show up with a "h" beside it.
Below are codes you may see in the DIC after converting to Speed Density. They can't be disabled, but are instead changed to not report a MIL light. So they are there, but won't mess with a vehicle inspection (if your state has one).
P0101 Mass Air Flow (MAF) System Performance
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
So 2 different shops didn't notice that wasn't capped or maybe it was and it blew off on your way home? If 2 shops missed it being uncapped they ain't very good shops.
P0704 Clutch Switch Circuit (M/T)
Did you even look up the codes before posting? So far none of them have to do with a vacuum leak. Here's a link to a list of codes.
Take the car back to the tuner and have them verify that P0103 has been set to:
2 - No MIL Light
Then it won't throw a code for it, but it will show up when you pull the codes in the DTC.
It should look like the picture below.
2 - No MIL Light
prochargedz (10-08-2015)
Did you not read my post #15? You're supposed to leave the P103 code. It's always going to be there with a SD tune. You can clear the rest but leave the P103 alone. If you don't have a speed density tune, then yeah, take it to the tuner.
