Mini alternator
Old 10-05-2015, 05:37 PM
westtexasbuff
westtexasbuff's Avatar
Default Mini alternator
Where can I get the mini alternator as seen in lots of twin turbo kits?
Old 10-05-2015, 07:49 PM
douniasg
douniasg's Avatar
I have one. $100 and its yours. I can send pics to your email. Its been sitting around for a while but was rebuilt before I removed it. You will still need to figure out a bracket and fuel rails. I think the stock rails will clear it. Aftermarket rails will definetly be in the way.
Old 10-06-2015, 11:06 AM
Almost_There_1
Almost_There_1's Avatar
The top one one is a Race Proven ND 150
Old 10-14-2015, 12:29 PM
StuntHeavy
StuntHeavy's Avatar
Where can these be purchased?
Old 10-14-2015, 04:52 PM
Smoove
Smoove's Avatar
HRPworld sells the top one I believe but when I looked...I only the the "50" advertised..not 150...
http://www.hrpworld.com/store/defaul...nd50-mini.html
The second pic is of my car, I will be with the car on Saturday. If you want to email me on that day, to remind me, I will check the brand and part number.
fixedroofcoupe@gmail.com
and I wanna say it's an oem replacement for an import or something. I have two, one failed on me, I'll end up getting it rebuilt to have a spare probably. I'll be by them both this weekend (saturday-so please email me during day)...the car is an hour north of me.
Old 10-20-2015, 10:11 AM
Smoove
Smoove's Avatar
My alternator(s)...A0407..stamped on one...I googled it...it's not the one I have so it's not a part number. Thats the only number/brand on mine,..other then it saing "135A" on a yellow sticker.
Sorry bud.
Old 10-20-2015, 12:32 PM
westtexasbuff
I just ended up clocking the alternator around like the UPP kits to make room for the header (twin turbo car), and made a bracket myself.
Old 10-20-2015, 01:58 PM
Almost_There_1
Do you have any pics of your bracket? The alternator has been the biggest pain to figure out.
Old 10-20-2015, 04:44 PM
Smoove
Smoove's Avatar
I only had a small piece of one of the brackets....I had to make the "Z" bracket myself, and shim with washers. It doesn't spin at all, even though I don't have a ton of tension on it but, it's not supercharged so belt grip, isn't as crucial.
Old 10-20-2015, 08:05 PM
douniasg
douniasg's Avatar
Glad you were able to fit a normal size alternator. You would of hated the mini alternator. I struggled with multiple charging issues. Does the alternator spin reverse?
Old 10-21-2015, 08:47 AM
Smoove
Smoove's Avatar
Only issue I have with the mini is a battery charging message when I first start it....hit reset button, gone...until next ignition cycle. Other than that, I have had no issues, even when I daily drove the car.
Old 10-24-2015, 05:55 PM
Almost_There_1
I'll bump this for anyone interested. I dig around the HPworld site and found the ND 160. I don't think they make the 150 anymore but don't quote me on that. I'd love to got one but damn they're expensive.
Smoove (10-27-2015)
Old 03-08-2017, 08:46 PM
sean.b
sean.b's Avatar
sorry to go all necro on this post, but I'm googling around now and cant seem to find the answer. I have an ND 50-90 mini alternator that I'm about to install, but it's 2 wire (green and yellow if that means much) and the OEM is 3 wire. i assume this is lacking a "sense" wire but I cant find which 2 wires in the factory harness to splice into.
you guys have pics of your installs or know off the top of your heads?
Old 03-08-2017, 09:14 PM
Chris Stewart
Chris Stewart's Avatar
I got a Ford alternator working on mine, using these connections. Hopefully this saves you some time.
sean.b (03-08-2017)
Old 03-08-2017, 10:25 PM
sean.b
sean.b's Avatar
cool, probably does. out of curiosity - which Ford alternator?
Old 03-08-2017, 10:52 PM
Chris Stewart
3G, more details and diagrams in this post
https://www.corvetteforum.com/forums...nger-side.html
To Mini alternator
Quick Reply: Mini alternator
