The Half Mile Hustle. PIC HEAVY
#221
So the leak is either the corner joint of tge block/oilpan/timing cover junction or the oil galley plug right behind the PS pump.
Side note, have I got a sledgehammer to the nuts story for you sometime.
Smoove (05-05-2016)
#222
Hang in there man, it's just an arctic white thing, right?
I feel your pain. I'm in the same boat, at this point there is nothing really pushing me to complete the car except for the fact that I want to enjoy it after all the hours that have been spent working on it. There is just something that feels good about completing a project.
I had a brief taste of what had been created last year and want to take it further. Just keep pushing forward, but take a break if needed. I took a break yesterday and it allowed me to think about how I wanted to approach the current situation and make the right choice.
You'll get there. You've already crossed many hurdles to get to this point.
such a pain this thing. I've had two artic white cars...both trained me the hard way. It is discouraging but I have come a long way as you said, I am this close, the car seems to be good otherwise, so I am just gonna get at it maybe tonight and get it done if possible. At least start it. Thanks bro.
I think I figured it out tho....and honestly, I am baffled, and a little disappointed in myself for not even thinking of it. Fortunately the technician working for us, did. Just talking to him this morning(i usually work on the car alone), mentioning the issue, he mentioned the valley cover, and that he had a car do the same thing once. Had an oil leak, couldn't find...etc.
Anyways we checked at the base of my throttle body area, and you can see oil. More than likely, that is it. Ordering a new valley cover gasket, and proceeding.
#223
Smoove that's a good point, I have had oil issue around my engine as well, never thought it would be valley cover tho, but I do have oil around the back of the water pump and under the intake I found. Re used the old gasket. Oil was all over the place.
#224
I really did suspect the front cover myself, as the location of the fluid path. I almost think I reused this gasket as well, since it was kinda new but, that may be where I made a mistake. I always replace gaskets, I have a a few new ones always laying around for various parts but, I wanna say I remember NOT having a new one and wanted to get it done, and reused. Definitely a mistake on me.
#225
I pushed some oil out of my front knock sensor grommet last weekend in ohio. I was not having any good luck in the mile events running over gate pressure last weekend.
#226
dang bro thats no good. I have the LS2 block with my knock sensors in the LS2 side location, top portion deleted.
Side note, I took off my intake, oil is everywhere. So, I found the leak for sure. New part shows up today so hopefully we'll be up again soon.
Smoove (05-09-2016)
#229
I'm 9 times out of ten a whiskey drinker....vodka is my morning drink....but I have been drinking lots of stella lately for some reason. So...I think we can work something out.
You still with that chick? You gotta come down to WPB if not and check out the local talent.
#231
Beer chicken is chicken seasoned on the grill with a can of beer shoved in their abdomen hole.
#232
Less problems bro.
On a side note...
..I ordered a pretty sweet valley cover plate....for an LS1 with knock sensor relocation(so basically a smooth valley cover).... however....I am a doucher...since, I have an LS2....and I needed a valley plate WITH a female bung in place to screw in my oil pressure sensor. So..... I just ordered another plate lol...for a Gen 4 LS engine...which is basically also a smooth plate BUT,...I can drill and tap it for a 1/8th port for the pressure feed. Or...I can just leave it a blank panel...and relocate the oil pressure to one of the other ports on the block, and just lengthen the wires.
Anyways....i'm a doucher. New parts arrive on Friday. So...i'll dabble in the car again and shoot for this weekend that it'll be road worthy and drip free.
Which means I can drive it....
#233
Update:
So, I changed the valley cover gasket and went with a new low profile billet plate. In going to a new plate, I had to drill and tap a fitting for the oil pressure to get to the sensor(oil sensor relocation kit) I used a 1/8th tap....then went up to a -6....then to a -8...to the 12mmx1.5 oil pressure sensor switch....which is now roughly along side of my driver side fuel rail.
Oil leak from valley cover is fixed....however....I am reading LOW OIL PRESSURE.... roughly 5psi...or lower. I thought, maybe it is air in the line...so I cracked the union before the sensor open to relieve pressure...at first, I didn't have anything come out...then it did started pushing oil. I then tightened...went back to digital cluster gauge....and still, same pressure. Cracked the line open again...still, had oil coming out, seemed more so, however my pressure did not change on cluster.
Is it coincidence? Did my sensor fail? Did I miss something on the install? I did a good job soldering the wires so I don't think I am having a wire issue. It was like 90 in the shop on Saturday so I honestly didn't invest much more time into it. Today I will. If sensor is good....I will end up just pulling my oil pressure from one of the side block ports but...kinda over the hunting **** down endlessly.
Also replaced my oil feed block, and tap'd that for the oil temp sensor. All in all...making progress but...always taking those parallel side steps.
#235
your perserverance keeps me perservering with my own car. power steering leaking from the ps cooler, oil leak from BOTH valve covers and a transmission fluid leak.
Smoove (05-17-2016)
#236
It does suck tho. Depending on your config, power steering cooler not horrible to get to...especially on a lift or safely high enough to get under vehicle(jack stands). Oil leak from valve covers isn't bad at all, just need a 10mm and 8mm socket and some brake clean(and new gaskets). Trans leak hopefully would be a bad fitting but is likely a pan/or o-ring seal failure. depending on where.
You definitely gotta love these cars to constantly work on them. That, or be broke enough to not be able to drop it off at a specialty shop and have it all banged out lol. I manage a shop....I have contemplated just printing a ticket for my own car...and running it through the shop and letting the crew do my dirty work but something about wanting to everything(within skill set) keeping me from doing that.
Today or tomorrow...I'll spend some more time on it and go from there. Thats all I can do.
#237
Update with cooling:
Faulty fittings. Manufacture is sending me all new designed fittings, and hose. No questions asked. Very stand up thing to do in my opinion. Parts will show up probably next week. I'll re-do the coolant process all over again, and go from there.
#238
you got that right. stay on target, stay on target.
i drive a black NA 99 camaro ss. im waiting on the right deal for an EB c5z.
I keep the ps cooler right above the front air dam so that is easy to get to. It will just be my first time working with AN fittings. I was told to choke up on my wrench to mimic an AN wrench. I think my trans leak is from the drain plug. my thoughts are that putting thread sealant on a drain plug is not a good idea, right?
we are the same. i prefer to do everything myself. there too many positives of doing it myself to have someone else work on my car. Learn something, know my car, save money. besides, most of the time i have someone else work on my car i end up disappointed.
id really like to get a lift. my car is low enough that getting all 4 tires in the air with a floor jack is kind of a pain in the ***.
When it rains it pours right?? Stay on target.
Smoove (05-20-2016)
#239
AN fittings aren't bad to work with, they're usually standard sizing. I see some trans companies sending back transmissions with thread sealant on the sensors. I don't see a problem with it however if it is a sensor leaking, sensors usually have a crush washer built into them. If it is a drain plug, you can use some thread sealant on it no problem. My car is also low...usually takes a few minutes just racking it up on a lift. Makes it a pain but....worth it. Keep hunting for the Z...you'll find it. They're great cars.... C5's are probably one of the nicest driving vettes(comparing it to all years that I drive weekly for work-c1-c2-c3-c4-c5-c6-c7) that I have ever driven. Just needs some modern updates...great car. I may want another just as a driver.
#240
im keeping up the search, every day after work! now that I think about it though, i should prob include a FRC in my search. perhaps nassau blue? it more than likely will be cheaper (so ill have more mod money leftover and i wont feel so bad if the mods blow a part of the car up!! (rearend))
a pal of mine had a black blow 04 z with a forged short block that made around 725ish rwhp. damn thing was like a missile.
