Torco to keep stock engine alive?
I know this has been beat to death.
I have a can of Torco and for whatever reason can't take the plunge and pour it in the tank. Lol
Anyhow I just want something to give a little safety for detination. Tuned on 93 pump and 100% meth but want to increase octane will either use torco every fill up or run a few gallons race gas to bump octane ms 109 or 260 gt plus maybe.
The torco thing just seems to good to be true cheaper and more convient than race gas hmmmm
works great, only thing i noticed with it is i had to change plugs pretty frequent running it. it turns everything orange and leaves a coating on everything in the combustion chamber. didn't do any harm, just killed plugs a lot.
For a day to day driving you're literally pouring money down the drain...or your tune is god awful and you're running too much timing.
For prolonged stints of full throttle with boost like the drag strip and dyno I use a party mix of 93 and 109. Usually get the tank down to 1/4 tank and will throw 3-4 gallons of MS109 on top of it just for piece of mind, and to keep the car from detonating and pulling timing (power). Keep in mind that ALL of my racing is in different parts of the country no where near the region the car was actually tuned at, so maybe its a little more important for me.
On the street, its just run of the mill 93 pump, and sometimes 91 depending on where I am in the country.
- Travis
Received 1,261 Likes
since you're using meth already is there really any reason to use it?... curious if there are any other benefits besides octane that meth will not provide
Are you talking all the time, or for when you're beating on it for prolonged times like the dyno or racing?
- Travis
- Travis
In the future I will have multiple tunes and run on race gas from time to time.
Tunes fine and doesn't detonate or anything like that. My car is not my daily and gets driven pretty hard everytime out so most of the time. I would want something in there to bump octane. I don't want to be tuned on race gas or torco just want a little bump in case of bad gas or something of that variety.
At the end of the day do what you want or what you're comfortable with. If you're tune is NOT meth dependent totally then you'll see zero added benefit from using Torco, except for the placebo effect in your brain.
Depending on your mix ratio, you might actually be hurting performance with the slower burn rate based on timing....just food for thought.
- Travis
2017 C5 of the Year Finalist
St. Jude Donor '08
Hi Robert,
Pretty good info here so far, I'll just add my 2 cents as a 10 year Torco user.
I agree, If your tune is safe on the 93 Meth/mix, it might be a mute point putting in Torco, especially while running Meth.
Now if your tune is on the edge, then Yes, Torco will help to stay off KR once things heat up. Also, Meth can fail slightly and change your A/F, it's nice to have the extra protection.
I will also agree, that if your compression is a bit low, and your tune is VERY safe, the slower burn could rob you of a little power...
Here's my situation. Been running Torco in every tank for 10 years. I run a reasonably safe tune with Meth injection. I like the added benefit of both meth and the extra octane, can't be too safe, and I don't like leaving much on the table either.
Most tuners add meth after 3-5 pounds of boost, then it's gradual. I like knowing that the octane is already there before I start to build much boost, I've got a built stroked 418 LS3, and it starts to make pretty good TQ before much meth comes in, so the added benefit of Torco allows me to keep good timing, and take advantage of that.
It takes a bunch of things to go right, if you want to consistently run 200+ MPH in the standing mile for 4 years in a row on the same Motor...
Check sig...
RGT (11-20-2015)
I run 2 gallons of 104 mixed with like a half tank of 91 when im running the car at the 1/2 mile events for extra safety considering i go full throttle into 5th gear for a while.
But i am tuned on 91 and meth
Thanks for the replies guys! I have no idea if I will be adding any torco or race gas but some really good points and info was brought up. I really would like to have hp tuners and be able to switch tunes and run on race gas so that maybe an option in the not so distant future.
Received 1,679 Likes
I too use Torco when I feel the need.... Most especially during half mile events...
