Gage question
Old 11-29-2015, 08:04 PM
topdown01
topdown01's Avatar
Default Gauge question
I have a three Gage bezel coming in for my C5...what do you guys typically monitor on a supercharged engine?
Also, I am thinking of ordering digital gages...unless there is a particular reason that you guys think it would not be a good choice...most like personal preference but perhaps there is a technical reason to stick with analog.
Thanks,
Kevin
Old 11-29-2015, 08:10 PM
chris308
chris308's Avatar
Boost, A/F, Fuel Pressure
topdown01 (11-29-2015)
Old 11-29-2015, 08:56 PM
Shoaf85
Shoaf85's Avatar
x2
I've been using the prosport gauges for a while now. Mainly for the warning feature. They are good quality from what ive seen and are pretty darn accurate from my personal experiences. The warning feature is programable (flashing gauge and an alarm) which was the selling point to me since it's hard to watch a gauge during a pull.
I'm using their fuel psi and boost/vacuum guage, no experience with their wide band.
Old 11-30-2015, 12:03 AM
_zebra
_zebra's Avatar
most guys have the 3 above.
i'm only running an MTX-L wideband & a Stewart Warner boost gauge
topdown01 (12-01-2015)
Old 11-30-2015, 11:28 AM
romandian
romandian's Avatar
i have afr and boost. i have yet to look at the boost gauge during a pull. im going to deinstall it. im logging, thought.
Old 11-30-2015, 03:43 PM
Smoove
Smoove's Avatar
Oil pressure gauge works well from factory, so aftermarket I use boost, two air fuel, and fuel pressure.
Old 11-30-2015, 05:07 PM
StealthFRC
StealthFRC's Avatar
i suggest a gauge with memory or warning. you will NEVER look at a gauge during a pull, just doesn't happen.
i use plx gauges, they are stackable so you can use one gauge for multiple perimeters. i have 2 gauges, 1 covers boost, FP, afr... the gauge has memory so after a pull i can see what happened, it also logs it as a graph.
the second is a obd II gauge that reads the stock computer so i can see all the stock perimeters along with use it as a code reader.
Old 12-01-2015, 11:23 AM
TX Z06 02
TX Z06 02's Avatar
I've been using the prosport gauges for a while now. I'm using their fuel psi
Prosport doesnt show a digital Fuel pressure gauge? are you using the oil pressure as the fuel pressure?
same here, their fluid pressure sensor says not to use in fuel cause it will corrode.
Old 12-01-2015, 12:28 PM
chris308
chris308's Avatar
I have the Prosport "Evolution" Series gauges. Boost, A/F, and Fuel all electronic
Old 12-01-2015, 05:12 PM
StealthFRC
StealthFRC's Avatar
I called them about that, they said its only in there as a warning for legal purposes. It's perfectly fine.
The following 2 users liked this post by StealthFRC:
topdown01 (12-01-2015), TX Z06 02 (12-02-2015)
Old 12-02-2015, 03:47 PM
TX Z06 02
TX Z06 02's Avatar
I really like the styling of the ProSport Evo gauges, but you dont get Peak/Alarm functions unless you go with the 60MM Premium versions. This wont work with 52MM Gauge pods.
I guess I'm gonna go with Innovate Motorsports MTX gauges.
Old 12-02-2015, 04:34 PM
Smoove
Smoove's Avatar
Yup, my fuel and boost both change colors when they below/above desired range.
Old video but, you can see my fuel pressure gauge drop and go red(lowered based pressure and didn't tell the gauge) but....you get the idea.
Old 12-03-2015, 10:19 AM
TX Z06 02
TX Z06 02's Avatar
Which gauges are those?
Old 12-03-2015, 05:06 PM
Smoove
Smoove's Avatar
AUTOMETER "NEXUS" ...but, I think they're discontinued.
Honestly, they match the stock cluster so well, I think they're awesome. Few bugs though since you've got one big module. All of the gauges plug into it. Cool setup...I think one or two gauges has an issue if I remember correctly. Gonna fire up the car next week, we'll see what works.
Old 12-06-2015, 02:49 PM
topdown01
topdown01's Avatar
Originally Posted by Shoaf85
x2
Thank you for the recommendation! I reviewed a bunch of gages...I liked a couple different manufactures but this one appeared to have the best price and style combo that I liked. I was able to get the EVO Series 52mm, A/F Kit, Boost kit, and Fuel Pressure kit for a total of $355 with shipping. I had to shop around but buy from 2 places saved me about $90!!
Old 12-06-2015, 04:07 PM
Shoaf85
Shoaf85's Avatar
Glad to help
Old 12-06-2015, 06:34 PM
chris308
chris308's Avatar
Plus they are based out of St. Pete.
topdown01 (12-08-2015)
To Gage question
Old 12-07-2015, 01:29 PM
Josh@AandASuperchargers
Platinum Supporting Vendor
Josh@AandASuperchargers's Avatar
Most guys do boost and fuel pressure, and/or WBO2.
AEM makes a really cool Boost/WBO2 2 in 1 gauge too.
Old 12-08-2015, 08:58 AM
PEETYZ
PEETYZ's Avatar
x2
x2 They saved me already from a faulty fuel pressure regulator.
Old 12-08-2015, 10:26 AM
topdown01
topdown01's Avatar
No kidding?! Cool!
Quick Reply: Gage question
