Wideband location with UPP Twin Turbo
Former Vendor
Generally right in the down pipe towards the rear where it connects to the exhaust is where we locate them. If you haven't already ordered your kit, we can add that to the build, just request it when ordering.
CK
CK
I use a wideband in each exhaust manifold, then the wideband controller narrowband signal is fed to the PCM. But I prefer to run SDOL.
CK will get whatever you need to make the kit the way you want it.
Thanks guys. I just wanted to see where everyone else has it. I currently have it in location where stock converters were and was thinking of moving it closer to turbo, like 8" after it
Not ordering a kit, I been running UPP kit since it was released... (still running internal WG )
Former Vendor
Where you have it is fine, they're a little quicker and more responsive the closer you get them to the turbo, but they're also subject to more heat. Most all of the ones we've ever done have been right about where you're saying in the lower 1/2 of the DP. Nothing wrong with it there.
