c6 z06 questions
c6 z06 differential questions
So what is needed exactly to delete the c6 z06 diff cooler? I know i obviously need the diff cover. I'm not sure if i need a diff fill plug or drain plug. and then i saw there is some other type of plug i need.
Received 1,261 Likes
I just used a c5 rear cover and 2 -6an orb plugs, one for the side cover and one for the drain
yes, the line fittings going into the trans and diff/cooler are 6an
remove the fitting and replace it with an orb plug
