APS oil scavenge system upgraded
Clean air enters the left valve cover and is pulled from the right valve cover into a catch can. Vacuum to the catch can comes from the intake and from behind the air filter on the right turbo inlet both using one way valves.
This is how I do low mount oil scavenge systems.
Oil feed:
Pull from the highest place possible, I usually use the oil pressure sensor port, either drill and tap the valley cover, or use an aeroflow fitting that goes between the valley cover and oil sensor with a 1/8 npt port off of it.
Two Swaglok check valves on each feed line, 1/8 brass style, 10 psi cracking pressure.
Oil return:
Low profile drain housings
Drain needs to be vented, i usually vent the drain housing or T fitting. Vent can run to the valve cover
Turbowerx mini scavenge pump
Swaglok check valve after scavenge pump 1/4 npt, 1/3 psi cracking or 1 psi.
-6 to valve cover
I use a 30 second timer on the scavenge pump after key off to clear any extra oil down there.
Most of the time the oil comes from key off situations where all the oil in the line from the scavenge pump to valve cover drains back into the turbos from the bottom. Also noticed oil coming from feed lines when the engine is draining down when you pull oil source low.
Since doing all of this, no more smoking issues and my turbos are lower than most of you guys.
Oil feed:
Oil return:
-6 to valve cover
Don't have to listen or even care, I have mounted precisions lower and more often than most without a single failure or smoking issue.
What I found is a turbowerx mini will pull up to 6 inches of vacuum with the car running and supplying the turbos with oil. Since precision ball bearing turbos have such small out restricters, the scavenge pump can only empty what is coming in at the present time, do a wot up to redline when your turbos are seeing the most oil, pop in the clutch and you are supply very little oil to the turbos, in this situation there is excess oil in the drain system that the pump can't remove. Also in a key off situation when there is no vent and no timer. Your drain system is completely full of oil plus add the oil that drains back through the pump from the return line that runs all the way up to a valve cover, you will literally fill your system up including filling your turbos up with oil. Since turbos do not have a convential seal, oil leaks into your exhaust and charge pipes.
Adding a vent, timer, and check valve after scavenge pump, eliminates all this. Scavenge pump is able to pull out the oil regardless what the turbos are being fed, removes excess after key off and check valves keep oil extra oil out if the drains.
It would never be sucking fluid from a vacuum, because there would never be vacuum created.
Oil is always moving, compressor/turbine seals are not perfect.
Air and oil will always be able to move.
If you are trying to replicate a gravity system and drain into a lower mounted reservoir, then yes you may want to vent the reservoir you scavenge from.
If not using this design and pretty much pulling straight from the turbos, you may not.
Try both and see what works for you.
And what Klug is describing about the Exa not coping with oil flow to the turbos....I dont believe it for a second unless the Mini flows much less than the full size Exa. Even more so as he's saying he uses BB turbos which will have a restricted supply and hence very little oil flow to begin with.
The Exa really does flow a shitload of oil.
I run 2 x full size -4 feeds to my turbos, no restrictions and the Exa pulls from both. I have no oil control issues at any rpm and my Exa pulls from right down by the base of the oil pan level from a high mounted location top left of the engine where my old Vortech used to sit.
Mine are sealed, mine works perfectly.
#33
I've only used the scavenge with JB...and on mine if I vented the reservoir it smoked like **** !
