?? For Nitrous Express
Running a single stage on your 2 stage 4 bolt plate kit, was told to run NOS and fuel into the same side but see a lot of pics of similar set ups running fuel in 1 side and NOS into the other.....
Does it make a difference ? Can't see how it would but have been told it does....
Supporting Vendor
The 78mm plate has to run one to each side. No option to run together on that plate. The 90mm and 102mm plates were built to be able to do 2 stages of nitrous. That's why you can go on either side but cant mix them. The nitrous wont stay across the fuel to atomize it if you do.
