Single Turbo C5 FRC Build Thread
#41
View My Video
First startup video in 5 months. Fresh oil, lifters are ticking. It's also only running on 7 cylinders. We ran out of spark plug wire for #8. Working on that as I post this.
I'm the same same way. Always missing a little something and just say F it I'll start it up anyways. Lol
RU_VVET (04-11-2016)
#43
#45
Dyno. Tuned by Jeff Lowry of Performance Specialties of Glen Burnie, MD. 606 at 10psi
Supercharged Mustang wanted to play. He's 610whp
Another race with a Viper this time. The Vette Slays them all on street tires.
#47
Hows the boost control with the wastegate routed that way? Any boost creep or spikes?
#49
Just wondering because I may do something like this if my current setup doesnt reach my goals.
#51
I absolutely love the sound of a dumped wastegate. It's exactly like a turbo car should sound. Like a passing jet.
I dropped the car back off yesterday to get a Mantic twin disc clutch installed, A/C line runs (yeah it has AC), and a MSD 2-step box wired in. Gonna turn up the boost after that.
#57
#58
Well we went to replace the clutch and as we removed the torque tube from the clutch and crank we discovered the pilot bearing was 80 percent gone and the input shaft was scoured.
I ordered a built 1000hp torque tube from RPM Transmissions. Should be here by next week, and then we can complete the install.
#59
L33 5.3L (Stock bottom end)
ARP headstuds
Comp trunion kit
Brian Tooley valvesprings and retainers
LS7 Lifters
CCP Jam Camshaft
Fore Innovations Twin Pump Fuel System
C6 Fuel Tanks
Holley Fuel Rails
FIC 1100 Injectors
Billettech/Mechman Alternator
Canton Racing Aluminum Coolant tank
Borg Warner S400sx374 Turbo
Precision 66mm Wastegate
Tial 50mm blow off valve
Grimmspeed Manual Boost Controller
CXRacing 2.5 into T4 Cast Flange
Assorted AN fittings and stainless lines
$1100 worth of assorted Stainless steel
A $150 Ebay intercooler
3.5 Aluminum Intercooler Piping Ebay
Mantic 9000 Twin Disc Cerametallic Clutch
RPM Transmissions 1000hp Torque Tube
Stock Trans
Stock Dif
AEM Failsafe Wideband gauge
Alky Control single nozzle meth kit
Ebay Coil Relocation kit
Custom length spark plug Wires
MSD 2 Step Box
Creative Steel Polyurethane Motor Mounts
Other custom radiator brackets
Stainless Steel Dowel Rods for Turbo and downpipe support
Heat Wrap for wires and hoses
Wire loom and zip ties
New Brake lines
There's a lot of other small things that had to be replaced that costed money.
Overall I'd say I have $32-35k just in mods and labor. It is in no way a budget build However it was money well spent. This car gets so much attention and it's a BLAST to drive.
