Beadlocks....anyone with a single?
Thinking about running a single beadlock on my CCW 16inch rears. Rear brakes won't allow for a double obviously, and I'm not wanting to spend the $$$ on a 15 inch conversion either.
So, is anyone running a single beadlock out there, 15 or 16. If so, have you noticed any positives or negatives from the switch from no lock, to lock?
Combo is in my sig.
- Travis
Combo is in my sig.
- Travis
i run a single and haven't had any problems. i was spinning the tires on the wheels a few inches without them.
actually my 60' got better but then again i went to a 15" at the same time
Discussed further with my chassis shop, and we've both come to the conclusion that at this point, my car HAS to be rotating the rim.
I'm headed down to Extreme Fab in CT on Friday to have the Ultra-lite locks installed while I wait.
Once back Ill install the tires with glue on the inside bead.
- Travis
- Travis
WOW!!! Those look great. Never seen anything like them.
