WB O2 - preferred mounting location?
Running Guns & Moonshine
I need to weld in a bung for my AEM wide band oxygen sensor / gauge and am wondering at what point in the exhaust is the best spot to place it.
At the base of the headers? Before the cat? After the cat? Preference for any reason on one side of the car vs the other?
If the car has no AIR system and it is programmed out of the car, can I basically plug the wb in in place of one of the after cat O2s?
#7 is notorious for going lean.
Driver's side, about a 12"-16" after the collector (before cat), attempting to slightly bias the #7 tube.
Platinum Supporting Vendor
Driverside pre cat any where you can fit it.
