Upcoming Supercharger project. Looking for advice about supporting MODs.
Hey. I've currently got a stock '03 c5 coupe that I'm going to be taking to the next level. My goal is to make over 600whp. I'm going to go with an A&A kit however the support mods are where I need some advice. So far my parts list looks as follows...
- A&A v3 Si
- Englandgreen Whiplash 2 Cam Pkg
- ARP Connecting Rod Bolts
- ARP Head Bolts
- Monster Stage 3 Clutch Package
- Mahale Forged Pistons/Rings
- Kooks 1 7/8 Headers
- ECS Trans/Diff Brace
- 17x9.5,18x10.5 c6 z06 wheels w/ Drag Radials on the rear.
Does this setup seem alright? Is it feasible to run stock heads?
- A&A v3 Si
- ARP Head Bolts
So you already have the Pistons and arp hardware installed? I don't see fuel listed anywhere. That is the second most important thing keepin your engine alive behind tuning. Yes stock heads are fine.
Nothing is installed yet. I will be doing all of it all once.
Fuel... How did I forget that lol. Alright I'll add the A&A fuel system upgrade to my list.
Get a good catch can setup, off road pipe for the exhaust, OD crank pulley, Alky control for meth and your good to go! Is this going to be mostly for the street or going to the strip a lot?
Supporting Tuner
- A&A v3 Si - get the Ti Trim, same price. Run a 3.8 inch pulley
- Englandgreen Whiplash 2 Cam Pkg - recommend EnglandGreen Mayhem II cam instead
- ARP Connecting Rod Bolts - not needed at that power level
- ARP Head Bolts - not needed at that power level
- Mahale Forged Pistons/Rings - not needed at that power level
- Kooks 1 7/8 Headers - 1 3/4 headers will work just as well at that power level
Does this setup seem alright? Add Alky Control Methanol Injection for safety.
Is it feasible to run stock heads? - Stock heads are fine
Alright my new list looks something like this...
- A&A v3 Ti
- Englandgreen Cam PKG
- XS-Power 1 3/4 Headers & X-pipe
- Monster Stage 3 Clutch Kit
- ECS Rear Brace
- A&A High Capacity Fuel System
- AlkyControl Meth Kit
- C6 z06 Wheels w/ Drag Radials
I'll probably throw some rotors, pads, and brake lines in there too.
Do you guys think 700whp would be a pipe dream with this setup?
- A&A v3 Ti
- ECS Rear Brace
- A&A v3 Ti
- ECS Rear Brace
- A&A v3 Ti
- ECS Rear Brace
Supporting Tuner
Read his post more closely. He has a base C5, bone stock. No 243 heads. I know 700 is possible with those mods on a ZO6 - I am putting down 709 whp.
Supporting Tuner
My statement still stands. Based on his list, which is what he asked about, 700 would be extremely difficult to achieve, unless he uses a smaller than recommended pulley, and is tuned very aggressively.
