Downpipe design with fender kits.....
About to redo the entire exhaust on my car. My buddy who is doing the fab is asking me where others put their 3"-3.5" dp route.
My current 2.5" setup is touching the tire when fully turning already. As far as i have seen, everyone puts it against the frame, nearly in the same spot.
Examples/Tips/ideas/suggestions?
Currently:
Currently:
I have 2.5" downpipes and mine seem to sit back more towards door and higher than those pics above. The only thing that did touch originally was the passenger down pipe to the bellhousing before I reworked it. Now I have clearance everywhere, but turbo are close to installed vent screens.
I have the 3 inch downpipes on my c5. Here is a link to some pictures ck posted.
https://www.corvetteforum.com/forums...post1584206875
Interesting. What size are your front wheels/tires?
I'll forward him your pics. We were basically going to remove my old down pipes, test 3" paths til he finds something that will work between the frame , oil pan and a fully locked wheel... TONS of space in the c5.... not. lol
Former Vendor
CK
Jason913 (05-04-2016)
CK, is there room to flip the turbo assembly around and run the exhaust out the bottom of the fender?
I'm going to chaulk it up to a badly fitted setup then if you guys say it can be done. My buddy will get it done then, no doubt there. May have to re-route an oil line or two but idc.
Thanks very much for the help fellas. Had no idea there were so many twin 3" dp c5 vettes out there to be honest, well done @ CK
Same exact thing here. 9.5" wheel.
Yeah, im sure with some time your buddy can get it to fit. My car is down right now getting a forged 370 lq4, and ill be strapping on the larger UPP turbos
Yep, that's what I meant, out the side of the fender at the lower portion. Guess I should have been more specific. I think it would work out well. Basically swap the location of the compressor and turbine.
