Water pump pulley sheared off again ecs supercharger
This is the second time in two weeks my water pump pulley sheared clean off the shaft. I replaced the pump last week with a Delco pump and today it sheared off again. All my pulley look good. Zero balancer wobble. Never had a problem until this year. Running ecs 1500 kit on a 6 speed transmission. I ordered a performance pump with a billet bolt on pulley and I hope this fixes the problem . Has anyone ran into this at all ? And this is the 6rib set up. I tightened the belt as per ecs instructions as well where the stock tensioner was at 80%max. I'm stumped.
Received 1,193 Likes
St. Jude Donor '15
Is it coming off the shaft or literally breaking the pulley itself?
a/c man (05-24-2016)
St. Jude Donor '15
If it's coming off the shaft then have it welded on
If it's breaking the pulley then that's a whole different issue. "Sheared off" makes me think it's breaking something.
Tusc (03-21-2022)
Received 1,260 Likes
dang, I see this every now and then but more than once on the same car in that short period of time is odd... how tight is your belt?
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,083 Likes
That is a rare to happen so fast to the same car, the pump you posted looks good though. One thing to check upon installation is that the mounting boss for the original tensioner, now our main bracket is the same height. I have seen them be off before.
When you have the old pump off, place it on a flat table along side the new pump for a quick verification of the two. That can save you a world of belt troubles down the line of they are off.
Water pump pulley
Did this pump fix your issue? I am currently on my fourth pump within 6 months. Keeps walking the pulley off the pump shaft. I looked at this pump but it looked like the hub was pressed on just like the stock one even though you can bolt the pulley on it looks like the hub can still break free from the shaft and walk off.
Tusc (03-21-2022)
This is an old a$$ thread, but I'll chime in. I had the bell rip off at the top just like the OP. It was on my very first drive home from picking my vette up from ECS. Chris had said he's only seen this happen two or three times before. Looks like OP was one of those 2 to 3.
I decided to go with a Meziere EWP.
