What kind is boost with a 4.5 pulley?
Got the car running good but I took it out for a ride and I'm only seeing 3lbs on the gauge. It's a c5 base stock motor and exhaust manifolds with an ls6 intake and stage 1 procharger p1. I've searched the site and found all different boost number for pulleys. Just curious how to tell if it's a boost leak or the pulley is too big.
That's a pretty big pulley. I was seeing 6lbs on my 4.0 pulley with a p1. I also have a blower cam, longtubes, etc. What's your other mods?
Basically stock motor. Just ls6 intake manifold, ported throttle body, 60lb injectors and an axle back b&b exhaust. So your thinking I need a smaller pulley.
Yea stage 1. Im making a leak tester and going to isolate the blower piping to see if I'm losing anything. If that's good then it's the pulley. I was told to start with a 4.5 but everyone has different boost ratings for that pulley. I'm thinking 4.25 would get me to 6psi.
My guess is that you may have one of the following:
1) small boost leak
2) unnecessary restriction before the TB
3) bad gauge
I'm running the A&A kit with a 4.25" pulley and I see 6psi. I also have heads (dart pro1), cam (228/232 .571 112), intake (Fast w/ LS2 TB), headers (shorty headers), de-screened MAF w/ nitrous express housing.
1) small boost leak
3) bad gauge
1) small boost leak
3) bad gauge
It was a boost leak. There were actually a couple. It was a used kit so it needed a few things repaired. Just took me awhile to find them all. Thanks.
