A@A V3 system is on...but do you add a breather filter on the oil cap?
NCM Bash 2008-2018
Location: Granby, MA Talladega Super Speedway Vettes 4 Vets Ambassador
Middle TN Events Coordinator
Cruise-In 1, 3, 9. 10 & 11 Veteran
So my system is done but right now is not running in any boost yet. Base tune only on it and no breather or line running to vent the crankcase. What's the proper way to do this on a 2002 C5 with a brand new A&A V3si system? If a breather cap is the way to go...do you just drill a hole right in the middle and then epoxy the breather filter to the cap? Any help and pictures would be great.
Platinum Supporting Vendor
Our kits come with a breather kit for the stock oil cap. Your drill hole in cap and thread in the 90* fitting, then hose runs down to SC air filter with another fitting to pop into existing hole in air filter base.
Make sure this vac line off TB is blocked off I had a shop do my sc kit and they missed this, it will blow boost directly into valve cover and pressurize the crank case with boost. Bad idea!
