Another Huron Speed Twin Turbo Build!
#122
TTBlueZ06 (08-19-2016)
TTBlueZ06 (08-20-2016)
#131
Easiest way around to remove the a/c drier!
Step 1. Remove the engine.
Step 2. Stand in the engine bay.
Installed using just the right tool!
#133
Hey Mike!
Well so far everything is going pretty smoothly, I had a slight alignment issue with the intercooler but it was resolved by drilling some new holes. I also decided to mount a intercooler a little differently than intended so maybe that's an issue I caused. The intercooler is high quality, what you would expect from Bell but i did find a few pinholes in welds that I will need to go over.
All in all its going great and we are anxiously awaiting the bad *** engine you built for this thing!
MVP'S ZO6 (08-21-2016)
#136
Making some changes to the AlkyControl system.. These nozzles look at lot better and allow you to thread them into a welded bung. No more bulky fittings or rubber grommets.
#139
#140
