BEATNU is Getting Twins From Huron Speed
Old 08-19-2016, 02:28 PM
  #81
Smoove
Smoove's Avatar
does anything need to be changed on the HOSE of the AC system when using the CTS-V compressor?
Or just bolt on?
Smoove is offline
Old 08-20-2016, 07:44 AM
  #82
TTBlueZ06
TTBlueZ06's Avatar
Or just bolt on?
Yeah, you need to make new hoses. Parts are supplied, but you need to lay them out and crimp the fittings.
TTBlueZ06 is offline
Smoove (12-12-2016)
Old 08-20-2016, 08:27 AM
  #83
McMuscle91
McMuscle91's Avatar
Are the lengths correct? I didn't crimp mine because I wasn't sure if the lengths were exact.
McMuscle91 is offline
Old 08-20-2016, 08:32 AM
  #84
TTBlueZ06
TTBlueZ06's Avatar
Nope, they need to be shortened.
Old 08-21-2016, 08:19 AM
  #85
0Superman09
Former Vendor
Superman09's Avatar
Shorter supplied hose we found good at 18" and the longer one at 28". We will be supplying these finished for future kits, just confirming on a few additional cars first what customers like best!
Superman09 is offline
TTBlueZ06 (08-21-2016)
Old 08-21-2016, 08:54 AM
  #86
TTBlueZ06
TTBlueZ06's Avatar
Old 12-11-2016, 05:14 PM
  #87
HardcoreABN
HardcoreABN's Avatar
So yea, a lot has happened in life which put this project on hold. I was in the reassembly phase when I realized I forgot to have my dual 450 fuel pump hanger made. Then the next week the Army decided to medically retire me and I ended up having to move from NC to WI half way thru the build. Then I spent a month going back and forth between WI and NC to make all the trips to move and to actually get out of the Army. It has been a rough few months and my family and I are currently living with my Mom until I can unfuck my credit - went over 2 months without a paycheck - and purchase a house.
Now, I have had some progress in the mean time. I have had a lot of odds-n-ends show up - vacuum lines, vacuum blocks, heat shielding, and a few more items. In the next few weeks my entire hotside - Turbo housings, manifolds, down pipe, and waste gate pipe - will be sent to Swain Tech to get their White Lightning thermal coating put on it. I took a job at a local speed shop and our fabricator is going to make my fuel pump hanger. While the short block is assembled, I am ordering new rod bolts on Monday as 2 felt a little soft when they were tightened and stretched.
I will be putting a Turbosmart eboost2 boost controller on it as well. Once I get the engine assembled, the manifolds back from Swain Tech, and get everything wired up I will drag the car to work and do the install there since it is heated haha.
Also thinking about putting the new Edelbrock Crossram intake on it and running it thru a single throttle body.
My apologies to Jon at Huron Speed for disappearing, life was shitty for a while but now things are looking better.
HardcoreABN is offline
Old 12-12-2016, 10:12 AM
  #88
Smoove
Smoove's Avatar
Glad things are starting to look up man.
Smoove is offline
Old 01-20-2017, 02:49 PM
  #89
red03vette
red03vette's Avatar
i hope things are going good for you and you get your setup finished, looking forward to the results. all the best to you sir.
red03vette is offline
Old 04-01-2017, 10:19 PM
  #90
HardcoreABN
Rotating assembly is at the machine shop after buying upgraded wrist pins....I thought I had them - I paid for them when I bought the rotating assembly - but realized I didn't when I ordered up a set for a customer's car. Oh was I pissed - I had to tear it back down to nothing....ugh....Fortunately with my new job (even though I am "retired") I can get all the rest of the stuffs I need at dealer cost.
Shooting to have it on the rollers in early May to get a baseline tune because I will need to break in the new clutch and new gears. Shooting for June to push it to see what it will do.
Old 04-17-2017, 08:28 PM
  #91
HardcoreABN
Picked up a DeWitts radiator and an eboost2 - both used. the Radiator was in great shape, however the eboost2 will be going back....something is loose inside of it and it rattles....not gonna allow that. I found an iron 6.0 block that I am picking up for $350 next weekend so that will go to the machine shop and get honed out to 4.005 to fit my pistons. Also will need to have the mains align honed for the ARP studs.
Rotating assembly is back from the machine shop, will get it cleaned up and set the rods and rings on the pistons sometime this week. Also cut out the license plate dealy to bring more air onto the intercooler. Pulled the front sway bar off and this weekend I will be removing the power steering cooler.
Old 05-22-2017, 07:47 PM
  #92
HardcoreABN
The eboost2 was broken when it arrived so it went back. Have also picked up a LQ4 block and it is at the machine shop right now. Soon as it gets back I can start getting this beast back together.
Old 07-23-2017, 09:34 PM
  #93
HardcoreABN
Alrighty....will be picking up the new (to me) LQ4 from the machine shop Monday or Tuesday. From there the shortblock will be going together with new ARP2000 head studs, new ARP2000 rod bolts, new Calico coated Clevite bearings, and new Wiseco bearings. Valve spring shims should be here Tuesday so the heads will be together Tuesday night or Wednesday. Gaskets / seals, oil cooler / turbo feed block, oil cooler on order. Only things left to get are the boost controller, intake manifold, and secondary fuel pump, misc fuel / oil cooler lines and fittings.
My hotside is back from Swaintech Coatings, but they packed it like **** and some of the parts are damaged. Swaintech told me to eat a dick and it isn't their problem.
Shooting to have the engine together by the end of the month, and the engine ready to crank by mid Aug....
Old 07-23-2017, 09:35 PM
  #94
HardcoreABN
ANyone know where all my pictures went?
Old 07-23-2017, 11:17 PM
  #95
Milan
Milan's Avatar
Photobucket sucks now. Just use imgur or something
Milan is offline
Old 07-24-2017, 07:44 AM
  #96
Turpid porpoise
Turpid porpoise's Avatar
You have to pay stupid amounts of money to host through photobucket now. I converted everything to google photos and its all good again.
Turpid porpoise is offline
Quick Reply: BEATNU is Getting Twins From Huron Speed
