A&A - Identify This Part?
Old 07-24-2016, 10:42 PM
Tusc
Running Guns & Moonshine
Support Corvetteforum!
Tusc's Avatar
Received 3,268 Likes on 1,930 Posts
Default A&A - Identify This Part?
I installed a used A&A procharger kit of a type where it still ran the air to the driver's side.
I looked all over creation for a spot where this bracket would fit and couldn't find a convenient location. Sensibly, I would think it would go under the tube which goes left behind the radiators.
Does anyone have an explanation and/or picture of where this one should go or how to mount it correctly?
Old 07-25-2016, 11:55 AM
Big Jt
Big Jt's Avatar
its to hold up the 3 inch tubing that would go from the passage side where the blower is to the drivers side where the BOV is located on older systems. I have a picture of the location if need be.
Old 07-25-2016, 12:01 PM
Tusc
Tusc's Avatar
Much obliged. Yes, a picture would help. I would think it can go on the cradle. I'm just not sure where to be effective
Old 07-25-2016, 12:05 PM
Big Jt
Big Jt's Avatar
just bolts to the middle of they bar,anywhere would be fine. i used to have one but just use zip ties now.. ill look for the pic.
Old 07-25-2016, 09:10 PM
Tusc
Tusc's Avatar
What bar?
Old 07-25-2016, 11:09 PM
Big Jt
Big Jt's Avatar
Sorry, meant the k member.., cant find the picture that i was looking for but is just holds the tube up..
Old 07-26-2016, 12:28 AM
Tusc
Tusc's Avatar
Now you've got me worried because I can't picture where/how this would fit and work with my tubes.
Old 07-26-2016, 04:03 AM
Big Jt
Big Jt's Avatar
here
Tusc (07-27-2016)
Old 07-27-2016, 12:20 AM
Tusc
Tusc's Avatar
You earned extra points for the artistry.
I'll have to just get creative with the mounting. I can picture the location. I just have yet to see a spot where it would effectively reach and support the tubes from the k member. I'll fab it up if I have to.
To A&A - Identify This Part?
Quick Reply: A&A - Identify This Part?
