Single Turbo FRC Build
#81
Finally got around to tapping the LS6 manifold MAP sensor port since the clip had broken off long ago and I was tired of using zip ties and sealant to hold it in place.
Used a 1/4" NPT tap WITHOUT DRILLING, the hole is just right for the 1/4" NPT tap, and then put some sealant on a 1/4" NPT x 1/4" barb fitting from fastenal and threaded it in.
If anyone is interested the barbs came in a 5 pack so I have 4 left I'll get rid of for $1 each plus the cost of postage.
#82
My angle grinder is MIA but I managed to clearance the passenger motor mount pedestal for the passenger side boss that is in the way using a sawzall and die grinder. It's not pretty but it fits now; I ended up having to trim more than expected as it hit the webbing above the boss and the boss itself. Also, got my starter mounted, knock sensors installed and all my LS1 sensors are swapped over. Ended up ordering a new McLeod steel flywheel because the dowels on my Monster flywheel are in the wrong positions and I thought about the fact that it had been resurfaced so I would probably have to shim the slave and what not so I decided I'd rather just get the McLeod. That comes in Monday and then I drop her in.
#84
I pulled the pan off, drilled and tapped a hole but I cant find the fitting I had so I have a new one coming tomorrow haha
#86
Either right after it shows up or years down the road Ill stumble across it. It probably got lost during the move.
MVP'S ZO6 (01-30-2017)
#87
My buddy and I finished up the vacuum block. It is meant to fit right on the firewall above the fuel feed and evap hoses. It came out great and I am thinking about producing some more of these. It has 3x 1/8 NPT ports on the top and 3x on the bottom, 1x 3/8" NPT port on each end and 4 countersunk mounting holes.
#93
Bret pointed me in their direction as well. My wife found my very detailed list of what lines/fittings I would need and she ordered all of it as a surprise because she knows I've missed driving the vette.
#97
Fuel lines are done. Broke my plastic vise jaws while putting my catch can lines together so I'm waiting for that to finish my oil feed line, wastegate-> ebcs line and catch can lines. Other than that the car is together and I'm just going through and torquing every fastener I can think of.
Got my vacuum block mounted and mocked up the lines to my BOV and FPR. I ordered a weatherpack hobbs switch to mount to a 90* elbow on the top left port. I found a local anodizer who is going to take care of the vacuum block, the billet motor mounts I made and a few other odds and ends.
#98
Anybody have issues with fuel transfer from passeneger to drivers tank with a boost/vac reference FPR? Should I plumb it to a boost only source to avoid issues?
#100
It depends what your fuel pressure is set at, from my experience the jet pump system would not transfer fuel under 55psi.
