mains girdle
mains girdle
at what point if at all should i consider mains girdle
build is a 403 ls2 , procharger running 15-20 lbs of boost. forged bottom end, mains studded. england green cyclone cam, 317 heads with arp bolts , 10:1 thanks guys
With the block skirt design of the LS, I dont see the point. On say ,a SBF stroker, yes.
If you are gonna plan to make that much power, most would go to an iron block.
