Thinking about upgrading my motor but not sure on options
Hey guys quick question.
I'm currently running a stock LS1 with a Paxton Novi 2000 and a cam putting 635 to the wheels. I wanted to take the next step up in power but wasn't sure on where to go.
Am I wasting my time with a 383? Should I go to a 408 or 427? I'm assuming the price range is around the 15 grand mark?
Any info would be appreciated!
If I was starting fresh with a motor blower setup, I would stay with stock cubes or maybe a ls3 block and go with a bigger blower. You are going to make more power from the bigger blower than you would with a bigger engine.
Think so? Aren't I pushing my luck with a stock block? Plus I thought the Novi 2000 could reach 900hp
You are making 635rw with a blower and wanting to go up in power. The Novi 2000 blower is capable of making more power, so I would go up another 100 to 150hp using the blower to make the power. Make sure your fuel system is sized properly and see how everything works out by swapping pulleys to get to the desired range. There is no way I would spend $15k on an engine to make 800rw.
The 750 to 800 rwhp range is a great place to be with a C5 Corvette. It's a good balance of power, traction, overall control, and dollars spent.
P.S.
When you get to the 800rw mark and decide that you want to make 1000rw, take your $15k estimate and multiply it by a factor of 2.
P.S.
Received 1,261 Likes
I agree with this, 800-850 is going to be a damn fast car that you can also beat on without having to repair something every time you take it out
