Track results single turbo 6 speed :$
Hey guys just got back from my local track. They had a test and tune today. Overall im happy i didnt break lol. Got some good data from the passes i made. We made a total of 5 passes.
First pass was at 11psi
and the faster passes was at 13psi.
I had some issues with my dip stick popping off and blowing oil all over the place .Hoping to make it back out next month with some cooler air temps
For those of you who dont know my setup
04 z06 6 speed
6060 with c6 z06 diff
LS7 built
Custom single turbo kit (S480 T6 cast)
26x11.5x15 ET streets
04 z06 6 speed
LS7 built
Good 1st time out. That turbo has plenty left in it to get you well into the single digit range. I've got a Billet S480 in my garage built front mount kit. The billet turbo with the V3 wheel is a big difference from the cast wheel.
Any videos ?
Any videos ?
Its actually my second time out with the car. I went out last tuesday night but the track wasn't there. With my full street setup (28 inch drag radials and 18 inch wheels ) i ran back to back 10.86 @140mph with 2.0 60ft. I.figured with changing up to 26 inch slicks i would gain some speed and some et .That didnt happen
Next time out ill have 28 inch slicks. The car makes enough trq to turn them
Aiming for 15-16psi next outing
Yeah the billet 80 would do some work
Good results for you congrats. I'd work on the crank case ventilation pretty quick or you could hurt something. You can't have that kind of crank case pressure and not do anything about it. You'll be looking for a motor soon if you don't. GL! But nice results anyways.
We are currently running 4 inch down pipe split into dual 2.5 exhaust .We think this is out major back pressure problem .
I'm running a 4 inch exhaust to a "Y" which goes into dual 3 inch to the bumper . Unfortunately I haven't logged backpressure numbers. I'm also running a .96mm turbine housing.
Thanks . Havent had an issue on the street with breaking up but we only run 13psi and 11 degrees of timing at 10.3 AFR .Next time out goal is 15-16psi with 14-15 degrees of timing. Will need full 4 inch exhaust for sure to acheive this.Fingers crossed that we dont get any missfire. the 2.5 inch exhaust is really restricting boost. On the dyno we couldnt make any more theb 15psi. I was getting tired of tooling on the car so we left it as is and i enjoyed the car on the street .Summer almost over here soon so i think its time to let this thing eat!
That's fine. Looks like you have the 96mm turbine inducer wheel. I had an 87mm inducer on my original S480 and it was causing excessive backpressure due to my displacement. I had to do a custom built turbo to get a 96mm turbine wheel on my T4 unit .
I was thinking 750whp-800whp . car is 3500lb with me in it
also the temps where far from ideal . muggy and hot .
Back when we had the car on the dyno the temps where alot cooler and ideal to make power . We saw 800whp at this boost
goals next time are to have 15-16psi with more timing (875whp-900whp)
next month will have some free hp just with the cool air
My tuner keeps bugging me to power shift lol he claims 0.5 of a sec just doing that LOL . Will see next time out . I will say its alot harder to drive down the track then my old S/C setup . My 650whp S/C was super easy to drive down the track.
Nice passes for the first trip out... No doubt a turbo, stick car will be tricky to get the hang of at first..
Keep practicing, it will get there.
I would not power shift, you are just asking to break parts. There is not .5 in power shifting unless you just shift flat out terrible.
You'll be in the 9s before long.
His point to power shift was to keep the car in under boost . With the data log you can see the car falling out of boost .That when he told me power shift to stay in boost . I was not driving to break records . This week end was simply to make it down the track and get some data wich we got
Hoping i keeped motivated to go again lol the things we do a for a little time slip lol .
Yeah he has a point on the boost dropping after shifts and having to build back up again, I forgot about that...
Yes chasing a slip is addicting, at least until it starts breaking ****, then it gets expensive fast, the down time sucks...and then I just want to cruise...LOL
