Proefi c5 base map
Make sure the input/outputs match the pinout diagrams.. On my C6 there was a mistake on the TPS input. (AN01 and AN29 are both listed for the same function, AN29 was the correct one)
Yeah you have to be careful when using a can tune from someone else and they may have assigned something to a different location. So before trying someone else's double check all of the pin assignments. GL!
