Which engine oil for boosted cars?
I think we are talking about a 2-3 HORSEPOWER DIFFERENCE so personally, I would [strongly] suggest a heavier oil, for the added protection. But....if you have a MAX EFFORT build, and want to squeeze every possible ounce of power...go with the lighter weight. I just don't see the need for it.
Received 1,762 Likes
Think of it like this. A lightweight oil(0wt or 5wt) will have very little resistance in comparison to lets say, a 20wt. So yes, you would likely loose a tad bit power, probably not noticeable. If you went to a , lets say 50wt like how I did, you would notice that the engine revs, ever so slightly slower(you'd have to really know your car and the characteristics of how it runs, to notice before/after).
2017 C5 of the Year Finalist
St. Jude Donor '08
I run Torco 20/50 oil.
Question, what is he correlation between thinker oil and higher temps on a road course??
Redline 15w50 here. Has plenty of moly and zinc to protect the valve train and bearings plus it handles very high temps without shearing.
Thanks for all the info, and very informative. I also found a very informative link on camaro5 forum a few yrs ago that I could post, from Louis and anthony from LG motorsports regarding over the self synthetics. Long story short, To use either amsoil, redline joe gibbs ls30.
I have found that my best application would be to use the amsoil ZRod with the added zinc. The over the self synthetics have been watered down.
Now I know others like it, thats fine, but for high horsepower applications like my vehicle to stick with the ones I mentioned.
Smoove (09-26-2016)
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
Rotella T6 15W-40 here.
Oil weight will not effect oil temps. Oil temp will change oil viscosity.
So many people get all bent out of shape about running thicker oil but if the engine is in good shape thicker oil is not helping you. Thicker oil increases pressure right so think about what is happening. Increasing viscosity to increase pressure means you are sacrificing FLOW to gain pressure. I will take more flow over more pressure any day of the week.
I have a car that has 220k hard miles on it (not a corvette) and I run 0-w20 in it summer and winter with no problems. Matter of a fact the car likes the water like oil it gets in all the places it needs and quickly.
#33
I'm running:
Stock bottom end LS1
1) Dart Pro 1 heads (11:1)
2) 228/232 .571/.573 112
3) Headers
4) Fast Intake/90mm LS2 TB
5) Yella Terra rockers
6) MSD coils
7) A&A Procharger kit w/ 3.8" pulley (~10psi)
8) NOS wet kit / Nitrous Express MAF plate (75hp pills)
9) Yank SS3600 w/3.42 rear
10) Installed and tuned (HPTuners) by me.
Maybe 650+ rwhp (w/o NOS). I've never been to the dyno, but I can put my 345/35/18 tires up in smoke at 70+mph.
Nothing but Royal Purple HPS in my engine. 5w30 mainly.
3) Headers
6) MSD coils
Dunn (10-18-2016)
#36
WOW! LOL! Some of you experts crack me up with your analogies, but I get what you are trying to say. But I would think the better answer would be it depends on your motor and how the clearances are set up. On my high HP motors they have big clearances so to have any real oil pressure I do run thicker oils. On stock motor's I can't say that's always the best practice as some of the stock motors are set up real tight like .0010-.0015" and in that case I'd stay with something a little more normal other than making sure it has a good additive package for what your doing with the car IMO. I am a big fan of the Rotella T6 5W40 as its pretty good for being able to buy it at Wal-Mart or any other local place without having to order it on line and wait for it etc... Not saying its the best or end all be all for every application. And there are not a ton of oil's that are rated for passenger cars that don't have any good additives left after the EPA has had the manufactures remove most citing premature converter failure etc... I'm not an expert on the subject at all I've done a littler research and have friends that work or worked for some of the oil co. mentioned, but I really have just been inspecting my motors after various stages of abuse and continue to use what has worked well in my motors. GL!
a/c man (11-01-2016)
#37
If you have beefy enough parts in there, the stock clearances will be the best option. The reason for bigger clearances in some parts are just for making a compromise with too flexible parts not to jam.
Too many people look at the oil pressure at idle as an indicator of proper oiling. It is not.
#38
So what are your clearances then? I assume you refer to rod bearing clearances. I see no reason for any other (oil film related) clearances being looser than stock except for rod bearings if you have weak rods.
#39
LSX Block with .0003-.00032 main clearances
High Volume Standard Pressure Melling Pump
Twin Turbo with ball bearing restrictors
With Conventional 10-30 Valvoline im seeing 27psi hot idle 250 Degrees and Mid 40's cruising..
I was concerned about pressure too until I spoke with some people that I believe are wiser than I am in that field... I am considering installing the high pressure spring in the pump though. Wonder if that will actually raise pressure.... Ill be putting my Setrab 625 cooler back into the system this winter so I know that will induce some pressure drop and I would rather not have that happen.
#40
With 1300+ hp it might be hard to get rods and block which are so rigid that you could use ideal clearances so I see your point there.
EDIT: I assume also that it's a quess what kind of deformations there are and therefore the extra clearance is also a quess..?
