LG Motorsports Solid Engine Mounts
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
-RELEASE-
I should say re-release as we have had solid engine and transmission mounts for years now used in all of our race and track cars but we have recently made changes to them to make them lighter than the original designs.
Our billet aluminum C5/6 engine mounts are designed as a direct bolt in replacement for the OEM piece and have all required hardware supplied. They are slightly lower to add additional clearance for FAST intake manifolds.
MSRP $169.95
LG Motorsports C5/6 Solid Engine mounts
MSRP $169.95
Received 1,679 Likes
Anthony, you must have read my mind.... How did you know I was removing my engine this weekend? I may pay you a visit tomorrow... Firstly, any additional noises? vibrations in cabin? I once installed another vendors rear trans brace, drove it for about 5 miles took it home and removed it! It too was lightweight billet...
I'll call you tomorrow...
Former Vendor
Former Vendor
How much lighter than stock motor mounts? We're trying anything and everything to get weight off the Vette. We're still at least a couple of hundred pounds away from being truly competitive. With a non-FRC, non-Z06, it's really tough.
Former Vendor
If you are taking hundreds of pounds off the car then look to carbon body panels, lexan windows, lighter seats, no A/C, no heater, no pop up head lights, skinny front runners, smaller brakes....
If I had to take a guess, 1.5 lbs lighter per pair, but I have not honestly put them on a scale to measure. If I have a stock one around the shop I'll try and get some weights for you.
