new build at TTi
Old 10-31-2016, 10:27 PM
Chris Stewart
Chris Stewart's Avatar
Default new build at TTi
Sold the TTiX to do something more extreme. The guys at TTi are building a custom setup with Precision 7675s. It's been a tough year with George fighting 2 rounds of cancer, but he's pulling thru and back doing amazing work. It won't be long before this thing comes to life and making loud noises!
Old 10-31-2016, 10:49 PM
TheCartel
TheCartel's Avatar
Looks great man, interested to see how the cooling system will turn out.
Old 11-01-2016, 01:07 AM
SBCGENII
SBCGENII's Avatar
I bet this kit will make a little more power.
Old 11-01-2016, 09:59 AM
algZO6
algZO6's Avatar
Looks great!! Think it may be time for a glide with a bump box.
Old 11-01-2016, 10:14 AM
ForceFedC5
ForceFedC5's Avatar
Congrats! George does GREAT work!
Are you retaining your AC and all power accessories?
Old 11-01-2016, 11:05 AM
Smoove
Smoove's Avatar
I dig it.
Old 11-01-2016, 05:11 PM
Chris Stewart
Thanks, I really like how it's turning out. It's a race setup that can drive on the street, full exhaust, but no power accessories or AC to simplify things. Next up is an A2W intercooler.
Old 11-01-2016, 08:14 PM
slow ride
slow ride's Avatar
Drivetrain plans? It's going to rip that's for sure.
Old 11-01-2016, 10:05 PM
Chris Stewart
Gonna run the 347/4L60 combo until I can afford a LSX/glide or something like that.
Old 11-01-2016, 10:17 PM
Shoaf85
Shoaf85's Avatar
Looks good! In for results.
Old 11-02-2016, 08:27 AM
venomws7
venomws7's Avatar
Looks awesome.
Twin 7675 with 347ci gonna be very interesting to see.
Good luck man
Old 11-02-2016, 10:39 AM
C5 Pete
AMP Racing
Support Corvetteforum!
C5 Pete's Avatar
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Looks awesome Chris! Best of success with it!
Old 11-02-2016, 11:14 AM
slow ride
slow ride's Avatar
Probably a bit hard to light off, but I think he had nitrous at one point I have a friend with a drag car running twin turbonnetics 7268's on a 5.3 and he is just at the limits of building enough boost on the 2 step. I'm unsure if he is using something like antilag, but would assume so.
Originally Posted by venomws7
Looks awesome.
Good luck man
Old 11-02-2016, 05:40 PM
Chris Stewart
He did spec the parts to help spool. AR is .81, and header primaries are 1 3/4. If it's too soft off the line, I still have the plate kit.
Old 11-07-2016, 10:17 AM
Turbo-Geist
Turbo-Geist's Avatar
Glad to hear that George is back, he does great work. Also glad to see your build thread and get an up close look at how everything fits.
What size are the downpipes?
What parts are absolutely necessary to delete with this turbo placement? Obviously the ABS module needs to be deleted or relocated. Could you have kept the brake booster? Could power steering or a/c remain?
Old 11-07-2016, 02:50 PM
Nitrous Express & Snow Performance
Supporting Vendor
Nitrous Express & Snow Performance's Avatar
killer build
Let me know if you need anything.
Old 11-07-2016, 06:43 PM
Chris Stewart
The downpipes are 3" and tied into the midpipe. It could have cutouts or turndowns for a max effort later. It's also easy to install/remove, just a couple V bands. We thought about going thru the hood or fenders, but he found a way to make it work.
It required a custom alternator bracket, mounted in the AC location. It might be possible to run power brakes and power steering, we'll see how it turns out. Originally intended to make as much room as possible for the turbos, priorities you know.
To new build at TTi
Old 11-23-2016, 07:43 PM
Chris Stewart
Custom Precision PT2000 A2W intercooler is going in now. Looks like a tight fit!
Old 11-23-2016, 08:40 PM
C5 Pete
AMP Racing
C5 Pete's Avatar
Work of art!
Old 03-05-2017, 03:52 PM
Chris Stewart
I haven't updated in a while, here's some progress pics.
The Ford Ranger alternator was pretty big and they needed more space for exhaust. So they fabbed a new bracket and installed a Honda alternator.
New radiator and cooling fans installed flat, with some hard lines for routing.
Adapted 3" DP with V bands to a stock H pipe for street duty.
Relocated the ABS module to a more convenient space.
Merge pipe for the intercooler.
That's about it for now. The oil lines were just done, and the last item is to get a water/ice box and install in the trunk. We're thinking about a 7 gal tank with 1" lines and rule 2000 internal pump.
Quick Reply: new build at TTi
