C5Z LS3 rear mount turbo build
Old 01-20-2017, 04:15 PM
  #61
turboffr
turboffr's Avatar
St. Jude Donor '10
Here's a video from today with a sound clip of idle. I was out tuning part throttle and rolled into it in second gear as well. It spools quick!
Old 01-20-2017, 05:28 PM
  #62
junk c5
junk c5's Avatar
The streets are wet and cold here so I'll get more data on the muffler come spring. So far I've gotta good idle results. I was hoping for a few less decibels at cruising speeds (35-40) mph. You have to speak up a little while cruising in my car, but I suppose having a vert doesn't help either..
The next stage is to sneak an electric dump just before the muffler for when I have it tuned to 20lbs. I have a front mount and I ran my exhaust all the way back to the bumper.
Old 01-22-2017, 09:52 AM
  #63
etekberg
etekberg's Avatar
Man, I just love turbo whistle
Old 01-22-2017, 03:16 PM
  #64
FourG63 97GST
FourG63 97GST's Avatar
glorious, nice build
Old 01-22-2017, 05:29 PM
  #65
turboffr
turboffr's Avatar
St. Jude Donor '10
ID850's and ECS stage 1 fuel system are on their way
Old 01-22-2017, 10:49 PM
  #66
FourG63 97GST
What power are you going for, on what fuel?
Old 01-23-2017, 06:58 AM
  #67
turboffr
turboffr's Avatar
St. Jude Donor '10
I'm gonna tune it on pump gas + meth @ 10psi and go from there.
Old 01-23-2017, 02:57 PM
  #68
c4toc5
Cruising
c4toc5's Avatar
The dynomax quieted it down some but it's still loud
loud and proud baby!
Old 01-25-2017, 01:18 PM
  #69
merim123
merim123's Avatar
nice build. curious why you cut the back out, just easier to work with or did you modify so you can mount the turbo higher?
Old 01-25-2017, 01:40 PM
  #70
turboffr
turboffr's Avatar
St. Jude Donor '10
Yes much easier to work with and with the hump in I'm not sure how I could have fit the turbo to be honest. I'm going to make a panel to cover the hole...you won't even know it's there
Old 02-04-2017, 08:47 AM
  #71
turboffr
turboffr's Avatar
St. Jude Donor '10
ID850's and ECS fuel system came yesterday. Not it a rush to get it done though since we just got snow. Will get this installed and report back once I can take it out and finally do some tuning past 4psi.
Size:  808.7 KBName:  photo202.jpg
Old 02-04-2017, 10:32 PM
  #72
bmfvette
bmfvette's Avatar
Good stuff!!
Old 02-22-2017, 02:38 PM
  #73
turboffr
turboffr's Avatar
St. Jude Donor '10
Update....
Started street tuning with the ID850's and ECS Stage 1 fuel system. I also installed an AEM wideband and an AEM Tru Boost controller.
With the boost controller and running on the WG spring it's making 5psi (5psi spring). With boost controller on "A" setting I have it at 7-8 psi (45% duty cycle) and on "B" setting I'm seeing 10-11psi (65% duty cycle).
I have timing at 14 degrees and AFR set at 11.3:1 on 93 pump gas. It pulls like a freight train and has no problem making boost! I plan to put a meth kit on it and finish tuning but for the most part this project is done.
Video of 3rd gear pull. AFR was close to 10:1 here but you get the idea..
https://youtu.be/Rb_VySogSn4
Old 02-22-2017, 02:41 PM
  #74
etekberg
etekberg's Avatar
Did you tune it yourself?
Old 02-22-2017, 02:42 PM
  #75
turboffr
turboffr's Avatar
St. Jude Donor '10
Yes, with HP Tuners
Old 02-22-2017, 02:43 PM
  #76
etekberg
etekberg's Avatar
Yes, with HP Tuners
Awesome. I really admire what all you did. You really make me look bad
Old 02-22-2017, 05:01 PM
  #77
turboffr
turboffr's Avatar
St. Jude Donor '10
To C5Z LS3 rear mount turbo build
Old 02-23-2017, 08:35 AM
  #78
venomws7
venomws7's Avatar
Great build and work the car pulls & sounds great congrats man.
Looking forward for more vids and dyno runs.
Old 02-23-2017, 08:53 AM
  #79
turboffr
turboffr's Avatar
St. Jude Donor '10
Old 02-23-2017, 07:23 PM
  #80
TheCartel
TheCartel's Avatar
excellent work man!!
Quick Reply: C5Z LS3 rear mount turbo build
