Boost leak and Spark Plug gap?
I'm putting the final touches on my ATI install and was wondering what others have done to test for boost leaks.
Also, what gap have you been running on your TR6s.
Re: Boost leak and Spark Plug gap? (QuickSilver2002)
Double then triple check all hose connections. Make sure all connections are away from body screws(intercoolers) and then see how much boost you get. If there's a leak you might hear it but its tough to locate with all the different connections. Prayer helps.
( :blueangel:
( :blueangel:
