Meth Injection users
I apologize ahead of time if this is in the wrong section but I was curious for those that use meth injection, do you purchase the pre mixed "boost juice" or do you mix your own and what from. I've read up about people using wiper fluid good for -20 and mixing in some Heat but I was curious what were some other options. I live in florida and i'm assuming -20* wiper fluid isn't plentiful so any recommendations on type that I could order. Thanks in advance.
I live just south of Atlanta. I use methanol only. Heet on a per ounce of meth is not worth it. The math proves it. This does not even consider HEET is not 100% meth. Buy in bulk and don't look back.
Scotty_Z06 (11-29-2016)
thanks. I'm currently deployed right now on a DOD network so i've been trying to limit my searches for "making meth" or "meth" in general to avoid any red flags, lol.
Just get the pure M1 not the pre mix.
If you can find an alky circle track racer, you can pick up some that may have a little water in it for cheap. As long as your tune isnt critical with pure meth, it works fine.
Scotty_Z06 (11-30-2016)
Received 1,261 Likes
I run 100% as well, it's about $3 a gallon locally... if you are just using it for safety you can buy 100% and mix it yourself with water, that's much cheaper than wasting money on premix
Scotty_Z06 (12-01-2016)
Scotty_Z06 (12-15-2016)
just buy whatever meth you can find it doesn't have to be the expensive vp stuff
Scotty_Z06 (12-27-2016)
Received 1,254 Likes
2016 C5 of Year Finalist
I have bought alky from the local speed shop. I have run 100% for years. The latest R&D supports the idea of cutting alky with
distilled water, up to 50%. I don't go that far but I have started mixing with good results.
You can teach a ol dog new tricks!
Scotty_Z06 (12-28-2016)
I buy 100% from the local race fuel store for about $2.25 a gallon from the pump.
I have run 50/50 in the past and run 100% now. 100% is the way to go. Hits harder and makes more power plus the extra octane of 100% itself is some protection vs 50/50
just my.02
just my.02
