A&A build What 2 guages? fuel?boost?air/fuel? brand?
i have both of those they will show your peak boost and also plot it on a graph so you can see.
the plx gauges are nice but the modules take up a lot of space. it is nice that you can have 1 gauge and it can display multiple sensors and like i said it will save the info so you can view it after the pull.
do you have any additional sensors or is obd2 enough?
are you able to set alarms on the obd2 parameters not sure if its will work on obdII parameters or just their sensors.
