a lot of perfomance C5Z parts
ALL PARTS ARE From a C5Z06
408 C.I LONG BLOCK whats listed is whats included $7800
this combo has made (600 rwhp Na/919rwhp on a 300 shot/1283Rwhp Blower 24psi) with a nitrous and blower cams.
MAST med bore LS3 heads 255cc SS valves BTR .660 Springs
Proform valve covers with modification for -10AN breathers
Comp cam Trunion upgraded rockers
Brian Tooley Platinium valve spring kit .660
Brian tooley custom blower cam.
12:1 compression
Arp custom aged 625 head studs
PPF custom head gaskets from Sweden
Wiseco pistons
Eagle rods
Callies compstar stroker crank shaft
ARP 2000 main studs
Prepped half filled block with hard block
DBRODS Long block prep and assembly
Timing set
Gen 3 front cover
Gen 3 rear cover
Gm valley cover
Steam lines
blueprinted oil pump
6.0 Iron Block
this long block has ran flawlessly though nitrous and boost. stays cool in the texas heat always run on e85
NO Flywheel/clutch/balancer/alternator/ps/ac/wp/oil pan is included
VORTECH YSI RACE blower 10 RIB 2.5 inch pulley With ECS bracket, Modified Cartek Flip Drive, IW Overdrive Balancer with cog accessorie main drive $4800
DBRODS Custom Intercooler With Garrett Cores
Core Size 12H/4.5D/20W vertical pressure flow
will include modified radiator core Support. has provisions for wastegates and bov's $1200
Dbrods custom radiator with -20 coolant ends and Shroud with Spal Extreme fans. $700 core size 14H/2.5D/23.5W
ARH 2inch long Tube Headers Black Ceramic coated $1500
RideTech Muscle Bars Front(C5) and Rear(C6) $1500
Control Arms All Corners Upper and Lower With Ride Tech Delrin Bushings and PFADT spherical rear shock Bushings installed $800
GM C6ZR1 Rear Cradle, LG C6 Rear Toe Arms, RPM Stg 4 with Quaife Diff,
diff $4500
Lg toe arms $300
Sunocco VFN 5inch cowl Hood Professionally painted (both sides) Black $1000
Double D mods Tigershark front bumper Minor Scuff damage (will need repaint) $400
C5Z calipers, DBA Drilled and slotted 2 piece front rotors and drilled and slotted rear rotors with EBC red pads $1000
act Street Twin rated for 1150 Tq $700
All items can be shipped at buyers Expense
you can use paypal if you cover the fees
Questions? please email me at Jeremy.T.Willett@Gmail.com
12:1 compression
Wiseco pistons
Eagle rods
ARP 2000 main studs
Timing set
Gen 3 front cover
Gen 3 rear cover
Gm valley cover
Steam lines
6.0 Iron Block
diff $4500
Lg toe arms $300
IS this just headers or the H-pipe too?
