N02 nitrogen pusher system or bottle heaters?
Want to know whats the best option for stable pressure/temp. I just switched to this 2 bottle set up. I have a bottle heater from my single bottle set up and it worked ok. Should I buy an other heater for the second bottle or go the nitrogen pusher route?
I went the NANO route, but haven't actually tried it yet though as I didn't have the needed jets to suit....buddy's car has a bottle heater and I have nothing hooked up but after 2 runs we're both down on power... the NANO is supposed to give full power right to the last drop of nitrous....seems an easier install as well - no wiring etc and the local scuba shop and paintball shop can fill the bottle...
Supporting Vendor
Looks like 4an, hard to tell
Comes with everything you need plus a bottle gauge.
http://www.nitrousexpress.com/15939-...ge-14amps.html
PM me for a price shipped.
I would've bought a bottle heater instead of the NANO when I ordered the NX kit but I hate wiring with a passion, even simple wiring, plus I got a great deal on the NANO slightly used...everyhting came with it....not sure which way I'd go next time though, guess I'll see how this system works
I had a nano when I had nitrous on my car. It worked well but had a kink to it/. If the pressure gets to high in the nano bottle, it will keep the nitrous solenoid from opening when you hit it. You either have to purge the bottle off or cool the bottles temp back down.
Scott
ssrallyred (01-15-2017)
I'm a believer, the Nano made my nitrous setup, was able to simplify the wiring, also ran no gauges/extra lines that'll possibly leak.
also had to richen up the tune when I added the nano on my dry setup, it leaned the car out a full point, using the same nitrous jet.
main upside was the consistency, no matter what I did on the front half, once I grabbed 3rd and 4th, the mph was within 1% of the last pass
Received 1,679 Likes
I think that I too am going to pick me up a Nano kit...
