Finally built my own car! lots of attention to detail here
Old 02-17-2017, 01:52 PM
Cordes Performance Racing
Supporting Vendor
Cordes Performance Racing's Avatar
Received 1,228 Likes on 775 Posts
Originally Posted by Rkreigh
with that much power you might consider going direct port with the alchy
on Mr Le's F1X car he was putting down over 1200 and found the alchy was "carrying to the back" of the manifold and running the back cyl a bit too rich and the front a bit too lean (EGT monitoring on all 8)
the egt variance was over 200 deg which showed poor distribution which makes sense as the intake is designed for dry flow
after going direct port, the car picked up and ran much smoother and the variation dropped down to less the 50 deg difference
you could then "tune the pills" a bit to even that out if needed based on airflow variations in the manifold.
I'm going to give it a try on my next build but may use another set of injectors and staged fueling rather than just nozzles so I can get help from the wide band tuning and EGTs
ECS makes a nice setup, not sure of the cost, but at those HP levels I think it would help.
boost a muv!!!
not needed on my setup, and won't clutter up my engine bay with a direct port meth kit.
Originally Posted by jbsblownc5
WOW, Very cool build, and GREAT power!!
I'm also running one of your one off custom pulleys, works pretty darn good...
Thank you!
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
Old 02-17-2017, 01:57 PM
etekberg
etekberg's Avatar
what fuel?
Old 02-17-2017, 04:51 PM
Ksths2
Ksths2's Avatar
Nice!!
Old 02-17-2017, 05:29 PM
Supporting Vendor
Originally Posted by etekberg
what fuel?
e85
Old 02-17-2017, 09:47 PM
Detoxx03
Detoxx03's Avatar
Really nice setup.
Old 02-18-2017, 05:50 AM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
Nice work Joe!!
Old 02-18-2017, 01:50 PM
REKCUF
REKCUF's Avatar
2016 C5 of Year Finalist
Old 03-04-2017, 09:47 AM
Supporting Vendor
Got it back on the dyno with the meth kit installed to keep iats down and put the bellmouth on the supercharger.
1165 rwhp and 1004 rwtq. Favorite thing is because of the high compression I make 850 rwtq by 4500 rpm's and by 5k make right at 1k rwtq and carry it out to 7200. Who says centris can't make tq haha. Also got the new ACP carbon hood on. This thing fits absolutely like oem and is a super high quality true fully carbon hood.
Old 03-04-2017, 01:35 PM
Darion
Darion's Avatar
Joe nicely done! What a beast. Ya mention the fit of the hood was great, can ya point me in the direction plz, thx. I did a search but must be brain dead, didn't find what I was looking for.
PC
Found the info for the hood, must have finally woke up.
Old 03-04-2017, 06:44 PM
junk c5
junk c5's Avatar
Nice build. What's the backspacing on those rear wheels ? I'm looking at doing a set of 16x11 or 16x12 but I'm not to certain on a backspacing with a 28inch tall 295 drag radial.
Old 03-06-2017, 09:49 AM
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes on 657 Posts
Looking forward to the results on track, nice build!
Old 03-06-2017, 10:14 AM
algZO6
algZO6's Avatar
nice gains. did you pick up any boost from the bell mouth?
Old 03-06-2017, 12:04 PM
  #33
Supporting Vendor
yes i did, from no filter or tube to a bellmouth i picked up 1 psi at peak and 2 psi in the mid range.
Old 03-06-2017, 02:43 PM
  #34
scott5
scott5's Avatar
Dream build.. That car is beyond beautiful.. Can't wait to see it go down the track.
Old 03-06-2017, 08:25 PM
  #35
Hallett
Hallett's Avatar
What an awesome build Joe your car looks awesome
Will you have it at the no-fly zone this weekend.
Hope to make it down there. 👍 Bob Stanfield.
Old 03-06-2017, 09:40 PM
  #36
Supporting Vendor
Thank you!!
Thank you sir! and absolutely I will
Old 03-06-2017, 09:42 PM
  #37
Supporting Vendor
Thank you sir! Made more power than a lot of people think a 2200R is capable of. I attached the graph to show off how much low end I make with this thing, god bless high compression and boost!!
To Finally built my own car! lots of attention to detail here
Old 03-07-2017, 07:41 AM
  #38
venomws7
venomws7's Avatar
Great build and work congrats the graph looks great for sure looking forward for the 1/4 results
Old 03-07-2017, 08:58 AM
  #39
Supporting Vendor
Not really a quarter mile car, I built this for half mile. If I wanted quarter I would have done an auto swap or picked a different clutch. I love driving the rps and how it feels in rolls but I can't cut a 60 in it to save my life lol. McLeod rxt I've done 1.5-1.6 no problem. Ran the car in Tucson on 19 psi and went 10.6 @149.8 with a 2.4 60 haha. That was before the meth too so it would pull timing for the higher iats. In good air on 25 psi it should do upper 150's.
Old 03-07-2017, 01:41 PM
  #40
Smoove
Smoove's Avatar
Hell of an expensive rod choice. Dope build.
Quick Reply: Finally built my own car! lots of attention to detail here
