125 Shot, Not enough fuel.
1999 FRC
"Returnless" fuel system with a Racetronix 255lph Fuel Pump.
PRC Stg 2.5 LS6 Heads
MS4 Cam
+supporting mods & bolt ons
makes 420whp N/A
Recently with a 125 shot it seems fuel pressure drops and car runs dangerously lean.
Dyno sheet below.
Red was .025 fuel jet
Blue was .029 fuel jet
im going to install the Racetronix direct to alternator power wire and re-assess, next would be to add a boost-a-pump.
other idea is just to go dedicated fuel system for the spray.
i figured the Racetronix 255 would be enough alone.
any other ideas?
MS4 Cam
makes 420whp N/A
Dyno sheet below.
any other ideas?
Wire upgrade will help a good bit, give that a shot for a quick and easy fix. If not up to par still I would go dedicated fuel system. Much safer and easier to fine tune!
Had same issue on a 150 shot with same hp ms3 cam and return less used the Hotwire kit and racetronix 340 pump took care of it .But have since went to stand alone cell for the nitrous cause plans are to spray a lot more .
I'm in the same boat. 436 NA and even on a 100 shot there is a slight lean condition right after activation like its sucking the rail dry for a mill a second. Tuner says is safe with the stock pump and a BAP but those are known to fail from time to time. I am going to go with a stand alone system. I figure its a win/win. Move the battery to the trunk and plenty of fuel pressure.
Just got to pay off Christmas first lol.
Former Vendor
When it comes to running a dedicated fuel system there are a few benefits to doing so. One benefit is to supply the fuel solenoid with its own fuel supply thus reducing the strain of the pump when pulling off the fuel rail as you are doing so now. The second benefit of using a dedicated fuel supply it allows you to use a higher quality fuel such as C16/Q16. Higher octane fuel allows you to reduce the chance of detonation, increase ignition timing slightly that will directly result in increased horsepower, torque and MPH in the 1/8 and 1/4 mile. We do offer a dedicated that doesn't require you to remove your battery and relocate it. Third benefit is you can switch the fuel supply over to a low pressure fuel system. When using for example 55psi as the fuel system is now when it comes to adjust fuel you have to change jets. On a low pressure setting 5,7,10 psi you can make 1/4lb fuel increment adjustments to richen or lean the fuel supply out if overly rich without having to change jets. Feel free to email me Houston@nitrousoutlet.com or call me directly 254-848-4300 EXT 109 and I will be glad to answer any questions that you may have.
ssrallyred (01-23-2017)
