Fuel for my Nitrous set up question!
Hey Guys,
I was on the phone with my Tuner this morning and he said with the heads/cam/nitrous set up I am doing I will not be able to run more then 100 shot without running out of fuel... He suggested I upgrade to the lingenfelter upgrade pump which is roughly 200bucks. Is that the way to go or should I just spend a little more and do a nicer pump set up? If so what are your suggestions?
Also, I have been informed that the LS6 manifolds break commonly with nitrous due to them being composite. Is that the case when running 100-150 shot or larger shots?
Thanks in advance! Any advice/assistance is greatly appreciated!!
Awesome04Vette (01-12-2017)
Wait, is your car a 2004? My car is an early 2002 so I have the older style tank. If you have the newer late C5/C6 style tanks I would recommend a Fore Innovations setup. They have some nice drop in setups and you can use a number of pumps with it depending what you need.
http://www.foreinnovations.com/category_s/383.htm
