Vortec
Vortec
Hi, I know I'm in the wrong section, but there aren't hardly any supercharged C3s, so I thought I'd pick your brains. Mine is a 6t8 gen 1 sbc that I recently installed a Vortec supercharger. It's a runner but I have a few issues to clear up.. This entire project was all customizing work, no kits are available. What I need to source out is the pipe from the charger to the carb. This is where I need your help. Thanks T
https://www.summitracing.com/search/...dividual-bends
You'll just make your own. Then you'll need a coupler with a step down probably. No intercooler huh, e85?
I figured I'd be making the tube, but It needs to be aluminum, blow off valve has AL mounting. As far as the inter cooler goes, that is on the back burner. Haven't had much seat time do to building this and would really like to drive it. Any ideas were to find 3"OD AL tubing and mandrel bends?
Thanks T
I'm so old school, E85???? LOL
Thanks T
Yes, it's the most expensive carb I ever bought. Had a few problems until I increased the return line from #6 to #10. The engine runs good. The blower discharge tube keeps coming apart at the carb intake. 2 1/2" pipe to 3"coupler required a bushing. Then I can proceed to get the timing curve right. Will probably have to do that on a dyno. Need to use laptop reset MSD box. So many variables, I'm so confused, LOL. T
Supporting Vendor
I've got a buddy not far from Wisconsin that I'm sure could fab you something up. If I had time, I'd offer to do it but I'm under the gun, trying to get a motor ready for a dyno session out of state. Send me a PM and I'll get you in touch with him.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
Another one of the little issues I'm having is that the hood needs to be forced to close. It's rubbing at the blower out port coupler. Tried clocking, need about another 3/16 of clearance. Since I can't lower the engine, I thought I'd raise the body. I ordered a new set of body mounts and some shims. The Ford GT40 sits at 40" in height. The 6t8 sits at 42 1/2' to top of windshield so en extra 3/16 really won't matter and if the wheel clearance looks to excessive, the car has the VPB dual mount spring package, which can adjusted to lower the chassis. So it's a good thing it's winter, gots alotta work to do. T
